Old 27th June 2010, 10:02   #1
santhosh_lv's Avatar
Thanked: 44 Times
Default Water in fuel indicator - Swift VDI
After driving my VDI for about 19,500 Km, i see the first problem where in the Water in Fuel Indicator started glowing on the console.
Ah, after a very tiring morning and hungry stomach , i had to stop the car immediately and gone through the booklet to see if there is any solution written. Called up the regular service center engineer and he advised me to drive down to his place for checkup.
Diagnosis : A.S.S have attached a large hand held and checked the entire computerised system, Checked if there is any problem with the battery before starting the cute little bypass surgery. They had removed the complete airfilter kit under which there was this diesel filter. removed about half a litre of diesel from the filter to check if there are traces of water couple of times. After couple of trials they confirmed that the "water in fuel sensor" is the one that is creating problems. Replaced under warranty finally with no labor charges ( Price of the filter Rs.1023 made Rs.0 in the bill ).
Overall i must say very good service by Maruti and i admire the availability of spares.
santhosh_lv is offline   Reply With Quote
Old 28th June 2010, 12:16   #2
wanderernomad's Avatar
Thanked: 806 Times
Nice to see that you are satisfied. These days the first thing most workshops do is to check the sensor and the plugs before opening the filter. But good that you got your filter cleaned all the same.
wanderernomad is offline   Reply With Quote
Lancer fuel gauge indicator Vid6639 Technical Stuff 16 21st January 2009 20:19
Fuel indicator in spark whether a correct measure of amount of fuel bkm Technical Stuff 2 3rd April 2008 14:24
Water in Diesel indicator in palio D sfilinto Technical Stuff 6 7th January 2008 11:04
Schematic for digital fuel level indicator Vid6639 Shifting gears 5 19th March 2007 23:00
Fuel reserve indicator by light or voice in Scorpio santhoshbkartha The Indian Car Scene 0 21st August 2006 14:02
