Old 28th June 2010, 00:11   #1
Lemon's Avatar
Default Ritz: High Pitched Whining
Hi All,
I have a week and half old Ritz VXi Petrol. Just wanted to check with other Ritz owners out there if the high pitched sound while accelerating through the gears is normal.
Also I hear a very slight tappet like sound from the engine when idle. Depending on the response I may have to speak to the dealership regarding the same.
Await your responses.
Lemon is offline   Reply With Quote
Old 28th June 2010, 15:55   #2
vnabhi's Avatar
Thanked: 1,311 Times
Please speak to your dealer. I don't own a Ritz but happened to drive my cousin's a couple of times. Neither of those sounds were heard in his petrol Ritz.
Old 28th June 2010, 16:15   #3
maglev's Avatar
Thanked: 90 Times
A slight tappet sound is pretty much normal in most cars, but do get the "high pitched sound while accelerating" checked as it could be a leak or crack in the air-box which houses the air filter and is directly connected to the air intake.
maglev is offline   Reply With Quote
Old 29th June 2010, 10:30   #4
pramodkumar's Avatar
Thanked: 947 Times
The high pitched whining during acceleration is usually the belt, troubleshooting is check if the noise persists when AC On /Off, if it goes off when the Ac is off then the issue is not with the AC belt, else it is, since its a new car you just might need to adjust the tension of the belt.
Pramod
High Pitched sound from my Civic during braking ? sunnysideup Technical Stuff 10 5th July 2010 11:02
Swift = Whining in Overdrive ballkey Technical Stuff 40 18th September 2009 10:22
Whining sound from speakers at low volumes... frankmehta In-Car Entertainment 36 24th March 2009 09:58
Low volume high pitched squealing noise in Siena 1.6 ece2k2 Technical Stuff 3 18th August 2007 20:53
Whining noise. sage In-Car Entertainment 14 8th June 2007 08:15
