Thread Tools
Old 4th November 2005, 09:13   #1 (permalink)
DCEite's Avatar
Default Strange noise from 800
whenever i revv my 7 year old carb 800, a screaching sound is heard.. i wonder what it is.. its a kind of screaching whistle.. (i have heard this sound in some old model Indicas as well..).. any idea?..
DCEite is offline   Reply With Quote
Old 4th November 2005, 10:44   #2 (permalink)
could be a alternater belt sound...get the belt and associated pullies / theri bearings checked....
Buffetfan is offline   Reply With Quote
Old 4th November 2005, 10:57   #3 (permalink)
2fast4u's Avatar
ya its only the belts. and i believe the screeching sound is occassional or mostly when you start to move from standstill, once on the move the sound disappears.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 4th November 2005, 13:09   #4 (permalink)
DCEite's Avatar
spot on!.. going to mechanic now..
Old 4th November 2005, 14:40   #5 (permalink)
tsk1979's Avatar
Make sure that the mechanic does not employ the "mobil oil" cure and actually tightens the belt.
__________________
Reclaiming.....!
Old 4th November 2005, 15:52   #6 (permalink)
n_aditya's Avatar
I had the same problem with my brand new 800.
Used to produce that sound only during the first start of the day (cold engine).... Got the timing chain /belt fixed and the packing replaced.
It is all right now.
So it may be the timing belt problem. Anyways dont ignore the sound rush to a mechanic.
Old 4th November 2005, 16:54   #7 (permalink)
ananthkamath's Avatar
I think you mean the alternator belt. Timing belts are cogged and can never slip to cause this sound. If they do, your engine is as good as scrap in the first few seconds of running.
__________________
Miata Turbo Is GO!!
ananthkamath is offline   Reply With Quote
Old 5th November 2005, 10:33   #8 (permalink)
2fast4u's Avatar
exactly. wonder if it slipped would like to have a view of the snapped pistons crank etcetc.
__________________
636
RB20DET NISSAN
Thread Tools
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 5 15th February 2008 12:13
Strange noise from Indigo. sajo Technical Stuff 12 7th May 2007 11:59
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Strange noise from speakers Vivekphadnis Ask the Gurus 25 21st January 2006 23:12
Powered by vBulletin
