Old 4th November 2005, 20:27   #1
Default pgm-fi
need to know how different PGM-FI is from the MPFI..
inmate is offline   Reply With Quote
Old 5th November 2005, 10:06   #2
rdkarthik's Avatar
Thanked: 11 Times
PGM-FI - programmable fuel injection system. Usually vehicles from the factory are in a fixed state of tune, so a programmable systems lets you tune the ecu the way you want it..
MPFI - multi point fuel injection is a type of fuel injection setup where each cylinder gets its own injector.
Other type is TBI ( throttle body fuel injetion) which has a single/double injector setup at the throttle body feeding all the cylinders.
A PGM-FI system can use either MPFI or TBI.
rdkarthik is offline   (1) Thanks Reply With Quote
Honda Motorcycle unveils new version (PGM-FI) of CBF Stunner wildon Motorbikes 26 29th May 2009 13:56
Heart Beat: Dil Thaam ke Khelo (TV Quiz Pgm) muni Shifting gears 3 28th July 2006 22:21
