Old 26th March 2006, 01:02   #31
SLK
SLK's Avatar
Thanked: 192 Times
Originally Posted by abhibh
Also in skoda the turbo charger kicks in after the turbine starts rotating ?
Turbo charger draws power from the turbine!... which instead runs from exhuast gasses.... (AND thats for all turbo chargers.. no indica/ skoda here)
SLK is offline   Reply With Quote
Old 27th March 2006, 12:01   #32
As has been rightly pointed out, the TDi on the Octy stands for Turbo Direct Injection, a moniker that became famous with the Golf 1.9 TDi when it was first launched. as far as i know VW even has a Trade mark on it. the tata TDi stands for turbo diesel intercooled.
as far as the 1.9 octy is concerned, it has electronically aided direct injection(Bosch's famous VP-37 pump) and a VGT...thats what contributes to the famous turbo sound and the smooth transient response...
IDI engines allow diesels to rev to higher speeds and were very popular alternatives to DI engines for pass car applications. But they also have much higher emissions and cannot achieve certification beyond BSIII. This problem has now been solved by the use of HSDI(High speed direct injection) and CRDI engines. Modern turbo diesels with a gen II/gen III CRDI/PD systems and VGTs(variable geo. turbos) have high rated speeds, stupendous low end torque(the beemer 330d has more torque than a m3) and excellent transient driveability. they are also durable, as proved by the Audi R10 turbodiesel (5.5 L V12 twin turbodiesel, 650 HP, 811 lb-ft of torque) in the 12 hrs of sebring endurance on march 18th.
BTW how do you guys get all this info on TML projects????
porsche_fan is offline   Reply With Quote
Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI kryptonite Technical Stuff 21 12th February 2015 01:05
Audi launches Q5 2.0 TDI, A6 3.0 TDi quattro discontinued sidindica The Indian Car Scene 14 23rd August 2011 15:57
New Tata Indigo TDI: With InterCooler Turbo Digital Vampire The Indian Car Scene 21 31st March 2005 21:37
