Old 1st July 2010, 20:43   #1
Default Dual mass flywheel?
What are the necessary changes in starter motor of diesel engine if we plan to change the ordinary flywheel with a dual mass flywheel?
I need opinion with a fair reason...
bhardwaja2 is offline   Reply With Quote
Old 2nd July 2010, 07:23   #2
1self's Avatar
Thanked: 270 Times
Firstly, why would you be using a dual mass flywheel, instead of a single mass? A single mass is MUCH more reliable than a dual mass flywheel.
1self is offline   Reply With Quote
Old 2nd July 2010, 13:21   #3
CPH
Thanked: 34 Times
+1
And it is much cheaper.
CPH is offline   Reply With Quote
Old 4th July 2010, 23:24   #4
reliability is not the criteria. Criteria is to develop technology. We can increase FOS of the DMF material wise and design wise as well. I am not sure about working of starter for the same.
Old 17th July 2010, 16:23   #5
guys, I am not concerned for the cost or anything...
And you people are not getting my question and approach, I am asking that what are the necessary changes to be made in starter motor if we replace SMF with DMF or CDMF...
Old 17th July 2010, 23:04   #6
Thanked: 660 Times
As far as my knowledge goes, you don't need to change anything in starter motor. There is one thing though, the starter motor groves needs to be serviced often of residue.
I will never recommend anyone to change to DMF on their daily drive. as its expensive and more prone to failure as it has extra moving parts. So the hassle is more than the advantage it provides.
-kenden
Old 18th July 2010, 03:21   #7
CPH
Thanked: 34 Times
-kenden
And try balancing one.
Clutch Plate - Reverse install with dual-mass flywheel rathsubhajeet Technical Stuff 44 19th September 2014 21:20
Flywheel Weight Reduction / Lightened Flywheels kpzen Technical Stuff 38 2nd February 2008 15:07
Flywheel vipul261 Technical Stuff 3 11th February 2006 06:31
Lightened flywheel& underdrive pulley on esteem anybody? Stage3Monster Modifications & Accessories 8 18th March 2005 20:24
