Old 5th July 2010, 14:14   #1
OHCVtec's Avatar
Thanked: 12 Times
Exclamation Honda City stopping abruptly
Guys,
Need your expert comments on this issue I am facing. I got my City back from the Honda Dealership after a body work(My neighbour crashed in my parked car). Since it was body work and the rear bumper needed to be replaced, I was forced to give it to Crystal Honda.
Since the time I got my car back, the car stops abruptly while driving. I have noticed that the Honda guys have cleaned my Engine Bay. I have noticed a similar issue when I got my car back from servicing earlier. The issue got resolved in a couple of days and was not very frequent back then.
This time the car is stopping very frequently . The Engine stops suddenly while driving RPM drops to zero .
OHCVtec is online now   Reply With Quote
Old 5th July 2010, 17:08   #2
bhp_maniac's Avatar
Thanked: 96 Times
Originally Posted by OHCVtec View Post
Guys,
If you are sure that the service center guys cleaned the engine bay, I think they might have managed to enter water into your electricals while cleaning. When the engine suddenly stops, are the other electricals still working, like your ICE and lights ?
bhp_maniac is offline   Reply With Quote
Old 5th July 2010, 18:59   #3
OHCVtec's Avatar
Thanked: 12 Times
I am very sure that they cleaned the engine bay. The other electricals do work, the car starts again after a couple of tries(at times more).
Old 5th July 2010, 19:20   #4
yzfrj's Avatar
Thanked: 118 Times
Might sound stupid. But have you tried and Italian Tune Up ?
Is there any "pattern" or its all random ?
Sounds like (water + electrical system) = gremlins
yzfrj is offline   Reply With Quote
Old 5th July 2010, 19:38   #5
OHCVtec's Avatar
Thanked: 12 Times
I am not aware of the Italian Tune Up
There is absolutely no patter. The car stops randomly in any gear.
Old 5th July 2010, 20:45   #6
ghpk's Avatar
Thanked: 192 Times
have you tried revving it to high RPM when you first start the vehicle in morning.
Does all lights on panel remain ON or they just went off when your car stops.
if yes, it may be a loose connection somewhere causing a sparking/mis-contact.
Old 5th July 2010, 21:17   #7
pranavt's Avatar
Thanked: 273 Times
When the car shuts off, does it start again immediately as you crank it?
Old 5th July 2010, 21:25   #8
aargee's Avatar
Thanked: 2,124 Times
Car stops, fine; but how does it start back? automatically or do you have to turn the keys again? What about other electricals such as light, speedo or tacho's needles? Do they also fall back to 0? Does the horn work?
Old 5th July 2010, 21:29   #9
nitrous's Avatar
Thanked: 283 Times
What other symptoms do you face?
Old 5th July 2010, 21:46   #10
Cesc's Avatar
Thanked: 252 Times
During power washing sometimes water enters the spark-plug area and prevents the car from starting. As the water dries up the car returns to normal. You can get a simple air jet blown in your spark plug area after servicing so that the water dries up immediately.
However I am not sure if this applies in your case as you have mentioned the car stops while driving rather than having trouble starting up. OTOH you have also mentioned that the engine area was cleaned so I do think that you can give it a shot.
Cesc is offline   Reply With Quote
Old 6th July 2010, 00:17   #11
OHCVtec's Avatar
Thanked: 12 Times
[quote=ghpk;1968257]have you tried revving it to high RPM when you first start the vehicle in morning.
Not tried that. I will give it a try
[/QUOTE ]When the car stops, the lights remain on.
At times it dose start immediately at times I have to crank it up few times.
Nothing at all, the car starts immediately without any issues, runs like a dream as always . While its running, the engine suddenly stops. Once I crank the car a couple of time it starts again and runs normally. Issue is its happening pretty frequently this time. When I faced the issue earlier(after the earlier service) it had happened just a couple of time and never happened again.
Once the car stops, I have to turn the keys again a couple of times to start it again. Light stays On, Tacho needles drop to zero, horn/ICE works.
Last edited by Jaggu : 6th July 2010 at 01:08. Reason: Back to back posts, use Multi Quote (Quote +) instead. Thanks
Old 6th July 2010, 10:10   #12
Jaggu's Avatar
Thanked: 7,664 Times
Check all the connectors in the engine bay, one of them might be loose, including the battery cable. Then move on to fuse's and relay's if all of them are properly fixed (no loose connection).
Old 6th July 2010, 10:24   #13
tanwaramit's Avatar
Thanked: 339 Times
very remote, but could it be fuel pump related issue ?
tanwaramit is offline   Reply With Quote
Old 6th July 2010, 10:25   #14
esteem_lover's Avatar
Thanked: 447 Times
Reading through your comments, the one thing that hits me on my face and i faced it a little while ago is the fuel pump relay. My esteem used to stop just like that and it will take a few seconds to restart only to stop again a little distance away. I changed the fuel pump, but it still happened and then there it was the culprit. Check the fuel pump relay. When it gets heated, it fails, then a little colder works again. Yes, the intervals get shorter and shorter as time goes by.
@argee... do you think the car is haunted ?
esteem_lover is offline   (1) Thanks Reply With Quote
Old 6th July 2010, 10:42   #15
nairrk's Avatar
Thanked: 31 Times
The engine stopping on its own, may be a reason for erratic fuel supply, means the fuel supply may be getting cut-off resulting the engine goes off often??
Kindly have check the fuel pump/fuel system leaks if any?
nairrk is offline   Reply With Quote
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 58 2nd July 2010 21:39
Why was Yamaha RX 100 production stopped abruptly? finneyp Motorbikes 33 27th August 2009 19:51
Tread depth and Stopping distance theMAG Tyre & Alloy wheel Section 0 10th April 2007 15:11
Chevrolet-Daewoo helps GM in stopping Toyota rahul_intlad The International Automotive Scene 3 9th March 2007 15:21
Electronic wedge brakes[Lighter, better, shorter stopping distance & in cars near U] 1Day The International Automotive Scene 3 11th November 2006 23:05
