Old 9th November 2005, 23:38   #16
Mpower's Avatar
Thanked: 1,687 Times
Black smoke means its running rich. It happens in diesels when you step on the throttle hard and due to turbo lag, the air is yet to catch up with the fuel. Should'nt happen at steady state cruising.
Old 10th November 2005, 01:52   #17
nitrous's Avatar
Thanked: 285 Times
Mpower, even Naturally Aspirating diesel engines have the problem.
Old 10th November 2005, 09:23   #18
I can't figure out how turbo lag is connected with this?
I thought the ECU would be fast enough to respond to any quick changes in throttling and make sure that the right proportion of air-fuel mixture is maintained. Is the loop that slow, or is it because of improper placement of the sensors?
rzoster is offline   Reply With Quote
Old 10th November 2005, 09:35   #19
ananthkamath's Avatar
Thanked: 63 Times
diesels dont have anything such as a right proportion of air-fuel mixture....in fact the engine speed is varied by making the mixture richer or leaner....if you go to a diesel tuner forum they discuss things such as "overfueling" meaning that when black smoke is coming out the tailpipe, max power is being obtained .
ananthkamath is offline   Reply With Quote
Old 10th November 2005, 10:01   #20
Thanked: 1,642 Times
You're right, Mpower - this happens only when I accelerate hard. Thereafter there's NO smoke even if I'm cruising at 120...it disappears once you lift off the throttle.
Steeroid is offline   Reply With Quote
Old 10th November 2005, 22:37   #21
Mpower's Avatar
Actually the problem is because the ECU is too fast.
These diesels dont have a mass airflow sensor. When you step on the gaspedal, the ECU thinks you need power and immediately dumps excess fuel. But you also need excess air to burn it and due to lag, it takes a while to get there, which is why you see the puff of smoke momentarily.
Nitrous, same concept in NA diesels too, but should be much less because of no turbo. Its mostly poor calibration of pump.
Old 10th November 2005, 23:19   #22
nitrous's Avatar
Thanked: 285 Times
There. U got it right now.
Old 4th April 2006, 22:47   #23
Thumbs up What about the Qualis?
I have never ever seen the Qualis smoking, have you?
No wonder taxi wallas want a relaunch of the Qualis.
Rayden is offline   Reply With Quote
Old 4th April 2006, 22:58   #24
adit1329's Avatar
correct me if i am wrong..but i read on the forum some place that if insisted, the tata guys do some mods to reduce the smoke..
one of the tbhpians has got it done...and has posted a thread on the same
adit1329 is offline   Reply With Quote
Old 4th April 2006, 23:36   #25
abhibh's Avatar
Thanked: 34 Times
Its because of bad quality of diesel used. Had the same problem too changed the pump to COCO (Company Owned Company Operated) and problem got solved
Old 5th April 2006, 14:51   #26
Thanked: 443 Times
Whereas the Innova with supposedly more advanced technology gives visible black smoke.
directinjection is offline   Reply With Quote
Old 6th April 2006, 11:30   #27
True.. 2-3 months ago, Tata called in all Dicors for an ECU update and EGR system revision.. Smoke emission has gone down drastically after this.. Now I only notice a hint of smoke while starting in the morning..
nitinbhag is offline   Reply With Quote
Old 6th April 2006, 11:41   #28
I agree. This was done proactively by Tata Motors and inot based on how often you pester them (or 'insist').
Smoke is now a good indicator of the quality of fuel - there is NO smoke when the fuel is good, while you will see a bit of (still acceptable) smoke when your fuel is adultrated. The trick is to look at your rear view at night when there is another vehicle behind you (their headlamp helps) when you accelerate hard - if there is a trace of smoke you've been drinking from the wrong pub.
Old 7th April 2006, 12:30   #29
Thanked: 28 Times
Well i hvn't come across this problem in Scorpio crde yet!
PRADEEP KUMAR is offline   Reply With Quote
Old 7th April 2006, 16:47   #30
cooldude1988765's Avatar
Thanked: 108 Times
My grandfather's Innova too had the same problem. Changing the fuel station solved the problem.
cooldude1988765 is offline   Reply With Quote
VAG's emission fraud - VW cheats in emission test Nitrous Power The International Automotive Scene 884 14th July 2018 02:29
Emission Monitoring Solution (EMO) to monitor Emission data in real time NPV Technical Stuff 1 3rd November 2015 21:28
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
High levels of CO emission - any answers? WhiteAttraction Technical Stuff 0 3rd August 2006 13:30
