Old 9th July 2010, 23:54   #16
rajivanoj's Avatar
Thanked: 45 Times
@ ramsys
Yes you can get the parts from ukkadam, but i am sure the problem is oil seal leak, and you can get it replaces from an good workshop.
My lancer had same problem. then i got it repaired with anamallais, but anamallais give job to autozone. You can ask autozone, But you should need original power steering kit (which consists of 3-4 oil seals) and your rack may require an hard chrome, since it may have worn out by few microns.
But get an quote from other workshop too,
rajivanoj is offline   Reply With Quote
Old 10th July 2010, 16:24   #17
Thanked: 701 Times
Yes, going for autozone is the best solution: once i have given an Uno diesel with same leak issue and they replaced the seal(they took 4k for that, but still the job was so reliable).
Except that they will take weeks to fix it.
ramzsys is offline   Reply With Quote
Old 11th August 2010, 22:05   #18
Thanked: 701 Times
After the suspension overhaul, timing belt change and a few mechanical works, the car is back. The power steering system is reported to be normal, and there is no power steering fluid leak/ drop in level now. Anyway i wish i convert it into a manual steering once i get the technical know how.
Old 11th August 2010, 23:16   #19
mura's Avatar
Thanked: 11 Times
Easy, you need the Steering box, idler pully and ACC belt from a non P/S 1.3 Ikon.
You cannot use the Power steering box as a manual box.
I did this to my Ikon some time ago, but fitted a new PS box before i sold the car.
I might be having the parts, PM if you want them. IIRC the cost was 5k for all items.
mura is offline   Reply With Quote
User Manual / Service Manual for ICE & other accessories Mr.Boss In-Car Entertainment 5 6th July 2012 12:21
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
Manual to Power Mirrors normally_crazy Modifications & Accessories 15 25th October 2004 21:14
