Old 30th July 2010, 10:40   #16
Thanked: 431 Times
Thanks SirAlec for the info. One brake fluid bottle is 'half liter' or 'one liter'?
Is there anything to watch out for when bleeding the brakes? How do I make out whether the mechanic knows the job?
jinojohnt is offline   Reply With Quote
Old 30th July 2010, 13:52   #17
ghpk's Avatar
Thanked: 193 Times
Its 500ml.
most mechanics would know how to drain and re-fill then bleed to remove any possible air bubbles. this would waste a few drops but its very important to bleed.
Old 30th July 2010, 23:15   #18
Thanked: 660 Times
Test drive extensively after the brake flush.
Anyone using DOT 5.1 brake fluid?? Shan2nu Technical Stuff 28 11th April 2018 17:21
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Brake Fluid Replacement - IMPORTANT vigsom Technical Stuff 50 1st June 2015 13:13
Brake Fluid Help! rohanarthur 4x4 Technical 4 6th July 2009 10:21
Brake fluid leakage- help required! santosh.s Technical Stuff 53 11th March 2009 23:16
