Old 12th July 2010, 16:46   #1
adrian's Avatar
Thanked: 602 Times
Default Diesel pump howl in Ambassador
Hello Friends and experts,
My father's car is an old Ambassador Mark IV and recently the diesel pump (rotary type), Lucas CAV started howling in low revs. Step on the pedal a little bit and the howling is gone. Is it a clogged diesel filter or should we raise funds for a new diesel pump?
adrian is offline   Reply With Quote
Old 13th July 2010, 00:09   #2
Thanked: 660 Times
Diesel Pump can be easily serviced at specialized shops, no need to buy one.
Old 14th July 2010, 13:46   #3
adrian's Avatar
Thanked: 602 Times
We got the diesel pump kit changed one year back when diesel started to puddle below the car and also seeped into the engine. Does Lucas TVS has got an authorized dealer / service center in Kerala?
Old 14th July 2010, 15:13   #4
Thanked: 660 Times
Lucas-TVS Sitemap
Old 14th July 2010, 16:05   #5
adrian's Avatar
Thanked: 602 Times
Thank you very much for the lead, SirAlec.
Old 16th July 2010, 13:38   #6
adrian's Avatar
Thanked: 602 Times
I took the car to the authorized HM dealer and they remarked that the howl is due to a stuck valve and they advised to tune up the engine. Any idea?
Old 29th July 2010, 13:42   #7
dmaheshkumar's Avatar
Thanked: 18 Times
Default Hi
hi,
Pumps are one of the main part in the engine systems.
If you have already serviced before one year means,no need to do it again.As your Meachnics said Adjust the valve.
Valve settings are the main one for the pick up in the car.If HM Isuze or Imported Isuzu means it will have overhead Cam.
So we want to remove the valve door cap (lies in the topof the engine).There the adjustment need to be done.
The mechanics will have the blades to adjust this.It will take 15 minutes only.Checkit and then you drive for a trial for around 10-15kms.
If its still persists ,Pump need to be changed.
Update this thread after your valve adjustment.
dmaheshkumar is offline   Reply With Quote
Old 29th July 2010, 23:56   #8
Thanked: 660 Times
"Stuck valve". This are a major head components.
if thats the case the engine behave erratically with lot of misfire. Is that the case.
Old 5th August 2010, 13:34   #9
adrian's Avatar
Thanked: 602 Times
Default Thanks for the help SirAlec and Maheshkumar
I got the engine tune up done at the HM authorized dealer and also got the diesel filters changed. They have done a wonderful job and now there is no howling sound. The engine is a lot more quiet and the pulling has also increased.
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 729 17th July 2018 17:59
2009 Ambassador Grand BS-3 2.0 Turbo Diesel and 1800 ISZ MPFI: Test drive and review sidindica Test-Drives & Initial Ownership Reports 66 20th June 2017 15:59
Second-hand diesel Ambassador? WindRide Sedans 12 25th August 2010 13:42
Battery / Alternator problem in Ambassador Diesel adrian Technical Stuff 5 11th December 2009 14:25
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 11:16
