Old 16th July 2010, 20:35   #16
Technocrat's Avatar
Thanked: 2,501 Times
Originally Posted by dadu View Post
Is this a MPFI Alto ??
Originally Posted by guptavis View Post
I also have an Alto 2007 which sometimes jerks. How can i find out if its an MPFI or Carb ?
The Alto always had an MPFI engine(s) there was never a carb variant.
Originally Posted by amit_mechengg View Post
open the plug caps. check if there is moisture inside them. blow with high pressure air.
Secondly also clean the spark plug and check the gap.
I think its more to do with moisture.
and yes one more thing, make sure there is no cut on the plug cap and the caps are tight so that water does not enter
Originally Posted by aaggoswami View Post
I have seen similar problem in many cars, mostly its due to moisture in caps, plus spark plugs that need gap adjustment. Moisture in caps is major reason if driven in very heavy rains.
It happens with many cars, I have seen Santro, Alto, even Getz 1.3 face this.
Along with this, clean air filter too.
I agree looks like a moisture issue, try to clean the Plug caps, if nothing works please get the issue diagnosed at the service center
Old 16th July 2010, 21:33   #17
pramodkumar's Avatar
Thanked: 858 Times
Happened to me when i drove my esteem in a rainy day, the car jerks and looses power, what you need to do is rev the engine at say 5-6K RPM and hold it for 15 minutes and then drive and see if the problem persists. Alto and car esteems have their plugs placed at a very weird location and water easily enters the plug holes.
Pramod
Old 17th July 2010, 11:14   #18
Thanked: 92 Times
I am pleased to report that the issue vanished as soon as I filled normal unleaded+ additive(System G?) (earlier Xtra premium). My regular pump attendant prescribed this on noticing the problem & now, only stable starts for me.
Try this & report back.
JustCause is offline   Reply With Quote
Old 18th July 2010, 18:53   #19
Thanked: 245 Times
As suggested earlier, use it for 2-3 tankfuls and then use only normal petrol. Then use every 10k Kms or if problem crops up earlier.
Old 18th July 2010, 20:25   #20
Thanked: 16 Times
Hello people,
just have to say tried System G in my Alto for the first time and was i overjoyed!
I think it may be psychological because somehow i felt a difference even while taking the car out of the petrol bunk! whatever it is cant act that fast, right?
PS: The pump guy put in G after he filled the petrol. On the bottle it says put G and THEN fill petrol. Is this going to make a difference?
guptavis is offline   Reply With Quote
Old 18th July 2010, 23:02   #21
amit_mechengg's Avatar
Thanked: 1,545 Times
it should be put while filling the fuel so that it gets mixed properly. anyways it wont make so much differrence.
System G does not make any differrence in just few kms. you have to use it atleast 1 or 2 tank fulls.
Old 19th July 2010, 12:33   #22
Thanked: 18 Times
what should be the remedy for the fuel cut off.because the first service is due and the dealership workshop shall have to rectify the problem.
hps aulakh is offline   Reply With Quote
Old 29th July 2010, 09:26   #23
dmaheshkumar's Avatar
Thanked: 18 Times
Default engines
There might be also a chance of water entered in petrol tank due to the heavy rain.
But many are saying that they are facing the problem means,surely this will not be the case.But the jerks in the engines caused because the injection is not happening to the levels.
May be air lock also can be there.
dmaheshkumar is offline   Reply With Quote
Vibrations upon engine startup - Please Help bond_bhai Technical Stuff 19 18th September 2010 20:35
New Honda City (NHC - August 2004, 68,000KM) - Engine Shakes On Startup - Need Advice anandpadhye Technical Stuff 9 19th December 2009 01:02
Windows Vista - White Screen on startup, internet issues sammyboy Gadgets, Computers & Software 10 28th September 2009 19:19
Baleno smokes white during startup dvinod Technical Stuff 23 4th November 2007 02:42
