Old 14th July 2010, 16:52   #1
Default Steering wheel problems of Indica Xeta
Hi all,
I own an indica xeta GLS 2006 model which has done 30K. 2 months back I encountered a strange problem - there was a wobbling of the steering wheel at low speeds and a thud sound at each revolution of the tyre. I kept on using my car for another month. The steering then got very hard so much so that every time I took a turn I have to re-wind the wheel to make the car run straight. To say the least the steering wheel got jammed at the new position after every movement. The power steering effect is gone and I wonder if any car is having such hard steering wheel, even those w/o power steering.
I visited many mechanics all of them suggested various reason like problem of - suspension, fluid pump, alignment and balancing, worn out tyres etc. So Alignment and balancing, servicing was done and the tyres rotated. 2-3 days after the servicing the problem persisted though the wobbling of the steering wheel disappeared.
Can anyone suggest what exactly can be the problem. Though I'm about to replace all the tyres.
pankaj_veerkar is offline   Reply With Quote
Tata Indica e-xeta petrol with 17.1 kmpl and e-xeta LPG sidindica The Indian Car Scene 7 9th July 2011 12:39
power steering lighter in Indica Xeta than in Turbo greenhorn Technical Stuff 9 30th December 2009 12:41
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
Aftermarket Steering Wheel for Indica Xeta silver baleno Modifications & Accessories 4 8th December 2008 19:25
Indica Xeta - First Experience-How Xeta won the race nirmalkumar Test-Drives & Initial Ownership Reports 12 20th April 2008 16:41
