Old 17th July 2010, 12:44   #16
Thanked: 103,527 Times
DCEite, either the adhesive has gone bad, or the rubber has corroded (typical Maruti cost-cutting). Choose windscreen experts without a second thought. Ask them to send their mobile van to your place and get the work done.
Old 17th July 2010, 15:24   #17
viper's Avatar
Thanked: 9 Times
Installing a windshield is no rocket science. Also the so called "glue" is actually a silicone based gel like substance which cures/hardens in approx 2 hours. It is applied using a applicator squeeze gun.
Only precaution to be taken is that the silicone is evenly applied and that there is no gap else you will have water leakage. There are diff makes of silicon and cost ranges from Rs350 a tube to over Rs.1500 depending on the brand.
Viper
viper is offline   Reply With Quote
The paint of my car is peeling off! ssbiitm Technical Stuff 17 17th May 2012 15:54
Peeling sun film. What to do? fre2bpowerless Modifications & Accessories 7 28th December 2011 22:08
XYG Glass or Saint Gobain glass HappyRoadie Technical Stuff 10 2nd June 2011 19:50
Rear glass net for Optra rendezvous Modifications & Accessories 4 6th June 2010 19:10
Benz W210 Pre 2000 suspension vs post 2000 Mohnish Technical Stuff 2 21st January 2009 19:48
