Old 16th July 2010, 09:32   #1
Thanked: 2,470 Times
Default Original Matiz Distributor Rotor
Hi All,
Just recently my 2001 Stock Matiz gave up
Diagonised with a faulty Distributor cap and Rotor.
We took out the cap and rotor from another Matiz and the car starts and idles perfectly, I got hold of Original Distributor Cap (GM PART) and a Rotor from JC Road Bangalore (DAC-Delphi Automotive Componenet) meant for the Matiz, but that Rotor turned out to be FAKE
Though the car is at Home, but not starting.
Can anyone guide me on where to get atleast 5 Distributor Rotors (Will stock it)
All ORIGINAL GM PART
Old 16th July 2010, 21:43   #2
Thumbs up DIY... and Done
4 days and not able to find Genuine GM (Delphi) rotor
Got and tried 3 rotors, all anyways were fake.
Bought the best of the Local one available. (he he....)
Allt the rotors just went round and round, never slotting in. And nothing worked.
And finally had to resort to some DIY.
Measured the Original Rotor stem height - 13mm
Measured the local Rotor stem height - 14 odd mm
Eureka........ ! Eureka....................!
Took out the file, marked that extra 1 mm, filed it close to 13mm.
"Plock..." goes in the rotor, slots a bit OK OK correctly,
I had got hold of the original Delphi Distributor Cap, screwed them in, connected the New High-Performance (BRAND-LIVEWIRE) plug wires. Put back the battery, put in the airfilter, connected all the necessary wires.
The moment of truth and ultimate test my DIY skills arrived.
Crank.... Craaaaaaaaaannnnkkk, Firrrrrrrrreeeeeeeeeee............. (yeehaaw.!)
Our good old Matiz roared, Took it out for a long spin, got it back home, parked it, tried the same thing again. Luckily no issues re-occured.
MORAL OF THE STORY: Even the local rotor does work, only if the height is set to the NOS Rotor
Old 25th April 2011, 12:22   #3
Default Matiz Distributor Problem Please suggest.
Hi All,
I am using Matiz 2001 SG model since 4 years.It is 60K on odo. I recently changed the Engine head as weter is leaking to engine. The water leak is fixed but now i am facing Distributer problem. I am getting vibrations in the engine.These vibrations can be felt while in traffic and the engine stops after some time.Even engine is stopping while in running condition as well.
My Mechanic is informing that it could be a Distributer problem (Delco).I had replaced Distributer earlier but that original Mando Make was not suited on my car.I later got some used Delco from some where and that worked for 2 years now.I am not sure about my recent problem. If i wants to change Delco what should i do.Should i invest for a new one.
Can some one tell me where can i get a good used Delco for my matiz in Mumbai or Pune. If i take my car to them will they take money when that is working fine after installation on my car.
Please suggest if any of the matiz uses faced this kind of Distributer problem.
Thanks in advance,
Kchittilla.
Kchittilla is offline   Reply With Quote
Old 25th April 2011, 23:09   #4
knob's Avatar
Default Re: Original Matiz Distributor Rotor
I was under the impression that matiz had FI and ecu. The engine was derived from the m800 f8 engine. Couldn't the m800 distributor be fitted in this engine?
knob is offline   Reply With Quote
Old 26th April 2011, 00:11   #5
hvkumar's Avatar
Thanked: 3,365 Times
Have you tried changing the HT wire connecting the distributor? This sort of vibration happens when one of the 3 wires is defective - I have changed it 2-3 times. Another problem with old Matizes is electrical connectors, especially in the fuse box. They keep slipping contact and also get corroded, leading to loss of contact. I was able to solve the problem by changing the entire wire harness assembly.
hvkumar is offline   Reply With Quote
Old 26th April 2011, 01:14   #6
esteem_lover's Avatar
Thanked: 451 Times
What do you mean by HT wires ? What is HT ? Are you talking about the plug cords ? If so, yes, that could be a reason as well.
Old 26th April 2011, 02:01   #7
dhanushs's Avatar
Thanked: 4,504 Times
Yes, defective HT or HV cables can cause exactly similar symptoms, leading to faulty ignition.
Or, could it be a faulty ignition coil.
The cables from ignition coil to the spark plugs.
Old 26th April 2011, 09:15   #8
hvkumar's Avatar
Yes, as per what dhanushs says.
These cables can cause poor firing of spark plugs and I have faced problems with them before and changed them. Before you touch things like ignition coil, first check these. And the fuse box and electrical connections too.
Old 26th April 2011, 23:00   #9
Thanked: 451 Times
That is all you need to change. I am sure your problem will be set right.
Old 26th April 2011, 23:25   #10
Originally Posted by Kchittilla View Post
Hi All,
Thanks in advance,
Kchittilla.
I feel,the trouble is with these things
1) Blocked petrol sensors
2) Carbon deposit on the main sensor
3) Fowled spark plugs
4) Bad spark plug cables
Its actually the other way round.
The Suzuki engine was derived from the Deawoo block. Just have a look at all F8 engines, the Block Die cast still says DCM
M-800 Distributor will never fit the Matiz.
Rotor Plate for KB 100 RTZ sapna gurukar Motorbikes 8 13th April 2011 10:32
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
Ikon 1.6 - new O.E rotor or after market slotted ones shazikon Technical Stuff 10 26th September 2007 10:55
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
