Old 17th July 2010, 11:35   #1
killjoy's Avatar
Thanked: 191 Times
Default ANHC VAT - Sport Mode
I checked and searched but could not find this piece of information. I recently test drove and also booked the new Honda City AT. I have been hearing that the sport mode in the Honda City is completely automatic but from the short test drive I had and what I have read so far this is what I could find, need help to check if these are right or different.
1. The D mode is automatic, you can use the paddle shift to downshift/upshift for short bursts of accelaration/braking but it switches back to auto quickly.
2. The S mode is also automatic until you use the paddle gears. Once you use the paddle gears, it goes into manual. But if I shift up to 4th and slow down suddenly, it downshifts automatically in order to prevent the car from stalling. Similarly, if I hit the redline, will this upshift automatically? I was not able to check that in the test drive, please help.
3. If I leave the car in S mode and use paddles for sometime, will it shift back to Auto in sometime or will it remain in manual until I move it to D?
4. The audio system says it can connect to ipod as well as USB, need to know if I connect an USB with multiple folders, can i navigate using the system provided by Honda?
5. Saw a nice thread on the Hondaputer done by Netarchie, does anyone know if there is a direct bolt on kit like that available?
6. Have not seen a lot of pics of rear spoilers for the ANHC, anyone have any?
7. Last, heard something about the ANHC not having great ground clearance. During the test drive, I loaded the car with 5 people and drove around but it didnt really touch anywhere, need to know if the suspension degrades quickly and if this is causing any issues?
Thanks in advance for your respones.
Cheers.
killjoy is offline   Reply With Quote
Old 17th July 2010, 12:27   #2
jesal's Avatar
that is there in the city only my civic does not have it at all so cant comment
2. The S mode is also automatic until you use the paddle gears. Once you us the paddle gears, it goes into manual. But if I shift up to 4th and slow down suddenly, it downshifts automatically in order to prevent the car from stalling. Similarly, if I hit the redline, will this upshift automatically? I was not able to check that in the test drive, please help.
it will not shift up automatically only shifts down to prevent stalling i guess. it goes all the way up till you change gears.
it will not shift to auto you have to change gears manually.
not sure as civic has diff. functions
there are a few but the dash has to be made custom in everycase you will need a dashkit for the same. cpu can be arranged out of the box.
a few are around but i think only a lip spoiler looks good. unless you want to eat pav bhaji or hang clothes with those big spoilers which just add weight, not like youre going over 200 right ?
if i can live with a civic in bombay and my place here without touches i dont think the city comes close to touching i also have the city cvt no touches there too, so youre safe
jesal is offline   Reply With Quote
Old 17th July 2010, 12:33   #3
Thanked: 544 Times
My replies are in bold
2. The S mode is also automatic until you use the paddle gears. Once you use the paddle gears, it goes into manual. But if I shift up to 4th and slow down suddenly, it downshifts automatically in order to prevent the car from stalling. Similarly, if I hit the redline, will this upshift automatically? I was not able to check that in the test drive, please help. Yes, it is supposed to up-shift on redlining
3. If I leave the car in S mode and use paddles for sometime, will it shift back to Auto in sometime or will it remain in manual until I move it to D? It will not shift back to Auto
4. The audio system says it can connect to ipod as well as USB, need to know if I connect an USB with multiple folders, can i navigate using the system provided by Honda? Yes
7. Last, heard something about the ANHC not having great ground clearance. During the test drive, I loaded the car with 5 people and drove around but it didnt really touch anywhere, need to know if the suspension degrades quickly and if this is causing any issues? No, suspension doesn't degrade. Probably you did not encounter a huge hump during test drive
Cheers.
Guna is online now   Reply With Quote
Old 17th July 2010, 14:02   #4
jesal's Avatar
if it upshifts and downshifts by itself whats the point of paddles. only down is auto the ups are manuals mate.
Old 17th July 2010, 14:09   #5
killjoy's Avatar
Thanked: 191 Times
thanks guys. i have seen on the old sonata v6, that it upshifts once you hit the redline. was not sure about the city, am still not sure....
Guna, you have the city auto right? can you please check and confirm? thanks in advance...
Old 17th July 2010, 14:23   #6
echo77's Avatar
Thanked: 33 Times
Add another qn:
8. Is it possible to switch the stick between D and S modes while in motion?
echo77 is offline   Reply With Quote
Old 17th July 2010, 14:35   #7
Akshay1234's Avatar
Thanked: 7,242 Times
Originally Posted by echo77 View Post
Add another qn:
Yes that it fine.
Your assumption of number one is right.
In number two, yes it does downshift to prevent the engine stalling and it does not upshift when you hit the redline, it seems to be a feature in all newer honda cars. In older generation cars which had tiptronic it used to upshift on its own at the redline.
Old 17th July 2010, 14:35   #8
killjoy's Avatar
Thanked: 191 Times
echo, tried this during the test drive and it did shift but i am not sure if there is any harm in doing that, the sales person did not know...
Old 17th July 2010, 14:36   #9
killjoy's Avatar
Thanked: 191 Times
thanks for clarifying akshay. that will be nice. so going by the same logic, it will downshift only when it is about to stall and not otherwise right?
Old 17th July 2010, 14:40   #10
Akshay1234's Avatar
Yes, if you are below a certain speed in a higher gear it will downshift to prevent stalling.
Old 17th July 2010, 20:09   #11
killjoy's Avatar
Thanked: 191 Times
hmm, ok so it not actually a complete manual and the computer overrides at sometimes....
Old 17th July 2010, 22:03   #12
echo77's Avatar
Thanked: 33 Times
Thanks, akshay.
Now I am wondering between ANHC AT and Altis G.
Linea is giving me too many headaches before purchase, I wonder what will happen after purchase
Old 17th July 2010, 23:36   #13
sgiitk's Avatar
Thanked: 3,884 Times
S mode is Sport/Sequential. While you can up/down shift in D also, in S the car stays in the gear selected until you go too slow. Also, in S if you do not use the paddles then 5th gear is disabled and the shifting is more aggressive. Also for you get engine braking!
Old 18th July 2010, 00:01   #14
killjoy's Avatar
Thanked: 191 Times
does anyone have any pics of nice spoilers for the ANHC?
Old 13th February 2011, 19:46   #15
mdsaab's Avatar
Thanked: 446 Times
Default Re: ANHC VAT - Sport Mode
In D you can use the paddles for up or down shifting, however the car will return to full auto mode again.
In S once you use the paddles the car will stay in manual mode only downshifting to prevent stalling. But will not upshift even at the redline.
I saw an ANHC with a spoiler yesterday that had a spoiler which was done tastefully, it suited the car well. Sorry dont have a pic though.
mdsaab is offline   Reply With Quote
Engine choking in petrol mode, works fine in CNG mode fast lane Technical Stuff 12 28th August 2016 13:04
ANHC SMT or ANHC EMT with Caska HU alam86 Sedans 19 16th September 2013 15:59
Our 2011 Silver Honda City (ANHC) VAT: A journey from Dreams to Reality Bh.P Test-Drives & Initial Ownership Reports 32 6th April 2012 19:53
Nissan Maxima : 300 horses + 6 cylinders + paddle shift+ xtronic 6 speed sport mode nitroxx Test-Drives & Initial Ownership Reports 31 21st May 2011 03:31
This Valentine: My Wife's gift to me - The ANHC VAT (Polished Metallic) TheBeastFieast Test-Drives & Initial Ownership Reports 119 26th August 2010 18:51
