Old 10th April 2013, 13:32   #16
genesis's Avatar
Thanked: 309 Times
Default Re: Palio 2002 - Electricals - Lights Turn On When Key Is Off
Originally Posted by kavesh55 View Post
Dear Genesis,
Posting this 2 years late, but hope its of use to others. I had the same problem starting this week, remove the keys lights on. The culprit was a damaged lever inside the lock assembly & faulty connector. A circular device that connects to the other circular part having slots for accessory activation.
Solution-
Second hand ignition was bought from Chor bazaar and the connector was removed. You dont get connectors as spare. The lever was made by the lock smith. Replaced the faulty connector and it works. One key for the entire car.
Total damage- INR 1300 which is the cheapest bet, considering a new barrel itself costs 1800 + labour.
Replying 6 months too late: I too ended up doing a similar thing. Replaced the electronic/electric innards into the old assembly and now use one key only!
genesis is offline   (1) Thanks Reply With Quote
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
Stereo, lights etc working WITHOUT key in ignition TaurusAl Technical Stuff 9 5th October 2012 10:46
Palio - Flickering electricals mohit333 Technical Stuff 9 3rd June 2010 21:38
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
No right turn, but how about a U turn? adya33 Street Experiences 14 28th September 2006 20:10
