Old 18th July 2010, 07:01   #1
genesis's Avatar
Thanked: 309 Times
Default Palio 2002 - Electricals - Lights Turn On When Key Is Off
2002 palio 1.2. Wierd problem.
Reversing the car to get it out of the parking spot.
All of a sudden, car stops.
Now the car does not crank. But even wierder is the fact that when I remove the keys, the electricals, lights etc switch on.
If I turn the key to the crank position, the electricals remain on but does not crank.
There is a midway position where the electricals switch off.
The only abnormal thing I did before this happened, is:
Tried to remove some petrol from the tank for another vehicle (long story) and
put a plastic pipe all the way into the fuel tank. (Did take it out, since i
sucked in more vapor than petrol). The car did crank right after that.
Any insights are welcome. Right now I have disconnected the battery. The electrician will be coming by noon, but need to guide him.
genesis is offline   Reply With Quote
Old 18th July 2010, 07:42   #2
yogisays0909's Avatar
Thanked: 189 Times
I had faced the same issue with my esteem , it was due to hairline cut in the wiring loom and thanx to the rains water seeped in and shot the wires. in esteem wiring pass thru the left fender.
yogisays0909 is online now   Reply With Quote
Old 18th July 2010, 09:26   #3
clevermax's Avatar
Thanked: 445 Times
Looks like you Palio is possessed!! I'd like to know what the issue was, please post details here once it is resolved..
clevermax is offline   Reply With Quote
Old 18th July 2010, 09:33   #4
vigsom's Avatar
Thanked: 606 Times
I think there was a thread on Fiat Palio issues and solutions.That could help
Old 18th July 2010, 12:33   #5
planet_rocker's Avatar
Thanked: 368 Times
the accessory mode near the key hole get activated by any chance? how did it stall? did it shutdown on its own? or it could be the connections near the key hole.
planet_rocker is offline   Reply With Quote
Old 18th July 2010, 18:08   #6
genesis's Avatar
Thanked: 309 Times
You are kind of accurate. It is an ignition key assembly issue. The electrician came by and he can start the wire by shorting wires.
Now the ignition assembly is turning out to be very expensive.
Some 1800 for the plastic holding and 1200 for the lock and key assembly.
The electrician has asked for time to see if he can do some jugaad.
Any bright ideas or has anyone replaced their palio ignition key assembly?
(One reason this could have happened, is that I had a duplicate key made recently. Maybe the guy who made it jammed up something!)
Old 19th July 2010, 10:12   #7
genesis's Avatar
Thanked: 309 Times
Default Fiat Palio 1.2 2002 - Fuel Cut Off Switch
Can someone guide me as to where the fuel cutoff switch for a palio 1.2 EL may be located and how to reset it?
Old 19th July 2010, 10:25   #8
Thanked: 368 Times
it is located on the passenger side > below the dash board. it looks like cig' lighter.
Why, what seems to be the problem?
Old 19th July 2010, 10:29   #9
Thanked: 368 Times
The best solution - donot go for a juggad - get peace of mind and go for an OE replacement.
all the best.
Old 19th July 2010, 10:50   #10
genesis's Avatar
Thanked: 309 Times
Was wondering if it was preventing the key from being operated if it had tripped. But the mechanic can start the car using wires so it does not seem to be the case
Old 19th July 2010, 11:42   #11
Thanked: 368 Times
Fuel cut-off switch will get activated in case of an impact - this information is usually mention on the back side of the driver's side sun-shade
Old 19th July 2010, 22:26   #12
Thanked: 70 Times
all the best.
Hi Planet Rocker
Peace of mind if the OE will be in stock :P
I had issue with the headlight switch and the electrician removed the whole part and cleaned it properly and it started to work.
rikhav is offline   Reply With Quote
Old 19th July 2010, 23:00   #13
Thanked: 368 Times
i guess it is available. well that is what i made out from the OP's post.
else he can always opt for some other solution.
Old 20th July 2010, 18:25   #14
genesis's Avatar
Thanked: 309 Times
Posting The Solution:
The ignition key assembly was faulty. I had made a duplicate key a few days ago and apparently that caused a part of the assembly to short out.
Driver got a second hand ignition key assembly from Kurla CST (Bharatiya Auto) (it is a black cylinder with the key assembly at the end) and it was fitted. Works like a charm.
Only irritant is that I now have two keys. One for the doors and the other for the ignition.
Old 10th September 2012, 21:33   #15
Thanked: 28 Times
Default Re: Palio 2002 - Electricals - Lights Turn On When Key Is Off
Dear Genesis,
Posting this 2 years late, but hope its of use to others. I had the same problem starting this week, remove the keys lights on. The culprit was a damaged lever inside the lock assembly & faulty connector. A circular device that connects to the other circular part having slots for accessory activation.
Solution-
Second hand ignition was bought from Chor bazaar and the connector was removed. You dont get connectors as spare. The lever was made by the lock smith. Replaced the faulty connector and it works. One key for the entire car.
Total damage- INR 1300 which is the cheapest bet, considering a new barrel itself costs 1800 + labour.
kavesh55 is offline   (1) Thanks Reply With Quote
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
Stereo, lights etc working WITHOUT key in ignition TaurusAl Technical Stuff 9 5th October 2012 10:46
Palio - Flickering electricals mohit333 Technical Stuff 9 3rd June 2010 21:38
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
No right turn, but how about a U turn? adya33 Street Experiences 14 28th September 2006 20:10
