Old 19th July 2010, 16:31   #1
sidd25's Avatar
Thanked: 7 Times
Default Use of RPM
Being a newbie to automobiles I am asking this question which many of you will find stupid.
Pardon me if you find this question too kiddish.
"What is the exact use of RPM and what all can i do by determining RPM?"
sidd25 is offline   Reply With Quote
Old 19th July 2010, 17:11   #2
The Wolf's Avatar
Thanked: 58 Times
Hi Sid... welcome aboard!
RPM is Revolutions Per Minute, the rate at which a spinning object is moving. By determining the rate of that spinning object (like crank shaft, wheels, gears, pulleys) one can base combined mathematical calculations to find out speed, rate of change of momentum, gear strength, maximum power/torque curve depictions, tolerances warning charts etc
Hope the above helps...
The Wolf is offline   Reply With Quote
Old 21st July 2010, 22:15   #3
Thanked: 660 Times
i think you meant by usage of RPM meter on dash of some cars.?
They are commonly called RPM meters, or more technically Tachometer.
In simplest of terms it tell you when to change gear to get maximum efficiency from your engine. Basically most tacho has a red bar after some numbers. This is called redline. Ideas is to drive in such a way that not to let the needle enter that area.
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
RPM shoots up... gkrishn Technical Stuff 11 21st July 2005 23:02
RPM Store ! khaadu75 Modifications & Accessories 1 29th June 2004 22:13
