Old 7th September 2012, 16:49   #106
SS-Traveller's Avatar
Thanked: 11,626 Times
Default Re: Common Rail : Why is cold start tougher at higher altitudes
I was at a higher altitude, with lower night temperature. (4400+), I guess at that altitude, even slight increases in altitude can have an effect
I'm talking about Korzok, Tso Moriri, at ~4550m. (15,000'). Lowest night temp. (-)2*C, ambient at engine start was +1.5*C.
Highest altitude where the Scorpio mHawk engine was started by me, was at Korzok (Tso Moriri) on 15 June 2011 - altitude close to 15,000 feet. Engine started at 6 AM after overnight parking in open (no precautions or blankets etc.). The minimum temperature readout on the thermometer inside the car showed (+)1.5*C. No diesel gelling had occurred - stored cans of diesel in the back of the car were quite fluid. Diesel in the tank was treated with BG247 additive @1ml/litre approximately.
Starting results: Engine fired with one long 5-to-7-second crank, emitted one puff of light smoke, and settled into normal idling.
Edit: Sheesh... this is sounding like a mine's bigger than yours argument...
Old 7th September 2012, 17:25   #107
tsk1979's Avatar
Thanked: 16,421 Times
I was just guessing.
So maybe its not the engine block issue. Maybe something to do with filters. For example, if ice crystals for in sedimenter, fuel delivery will be blocked. I had to manual prime the hand pump to get fuel, and then start.
Does formation of ice crystals depend upon altitude?
Or is it that fuel at leh has higher water content which can lead to more water in sedimenter?
Old 7th September 2012, 17:29   #108
Thanked: 420 Times
Or may be it is "BG247 additive @1ml/litre approximately" which prevented gelling and crystals in case of SS_traveller just a wild guess.
amitk26 is offline   Reply With Quote
Old 7th September 2012, 20:43   #109
Thanked: 2,395 Times
Originally Posted by vibbs View Post
Pardon me for butting in, but are we seeing a loss in compression here? Its just that the final pressure is less owing to less initial pressure, doesn't the ratio remain the same? So IMO there is no loss of compression or CR. Or am I missing something here?
That comment was with respect to
Originally Posted by Off Roadie View Post
Just adding a link to a PDF file that supports the point that loss of compression results in starting issues.
Loss of compression in typical sense affects combustion because it fails to raise the temperature beyond the self ignition temperature of fuel.
CR (and expansion ratio) is a hugely important parameter, and a lot of equations are recast in terms of it. These equations all assume that there is no leakage. The amount (mole) of gas you start of with is what you end up with. When this assumption is no longer true, the equations have to be modified. One of the changes is a new 'effective CR' value.
The actual CR, as defined by initial volume/ final volume is mechanically set, and ofcourse remains unchanged.
Sutripta
BTW, you might want to revisit the stoichiometric part. Just a thought.
Old 7th September 2012, 21:43   #110
Originally Posted by vina View Post
Dada, what derivation do you want,
I was thinking of a textbook style explanation, starting almost from the beginning. You are right, actually not necessary. If we use the Wiki article as a base, hardly anything needs to be explained.
Practical engines are way different from our idealized, simplified models. Yet an understanding of that is an essential foundation.
Sutripta
Old 8th September 2012, 02:50   #111
Off Roadie's Avatar
Thanked: 126 Times
Sutripta
Was expecting you to point that out sooner =)
Promise you will give you a proper text book reply once I am on land.
Since I am really not aware about the ECU and all its parameters, maps (tables), I am staying out of it. If a Tata or Mahindra tech tell me/us that the ECU checks xxxxx I will take their word otherwise we are just guestimating.
I think there is a lot of combination of factors at work here. The surface friction between the injected, high velocity fuel particles and compressed gas may also play a part here.
So will do it with a cool head on land. Doing it all, over a cellphone is really challenging.
Off Roadie is offline   Reply With Quote
Old 8th September 2012, 21:05   #112
Normally don't react to opinions. ('Facts' is another matter!)
Sorry. Beyond my level of competence, and too lazy.
What happened to your own textbooks?
BTW, DMET?
Sutripta
Old 9th September 2012, 03:03   #113
Off Roadie's Avatar
Thanked: 126 Times
Nope Singapore Maritime Academy, all through, after schooling in India. No text books on board and it's been a while since I dwelled in the theoretical.
Old 9th September 2012, 11:54   #114
No text books on board.
Should have those on land. Unless you sold it off, or gave it to your juniors.
Sutripta
Old 9th September 2012, 15:29   #115
Off Roadie's Avatar
Thanked: 126 Times
Haha, you won't believe it but no text books on land either =p a desktop and the Internet should do the trick. It's a really long story but I learnt it the hard (and expensive) way that one hardly ever refers to the text books after schooling/college so gave them away one fine day.
Old 10th September 2012, 17:41   #116
SR71A's Avatar
Thanked: 72 Times
Originally Posted by PGA View Post
Your concept is absolutely in order. However converting it to practicality for ordinary vehicles may not be a great idea as benefits may not offset the penalty imposed by additional mechanical complications.
Anyway the problem is not of starting at all but only that off delayed lightup.
Infact, as brought out in the earlier posts by Offroadie, similar concepts are used to start bigger engines like the ones fitted on the ships and also those fitted on heavy earth moving machinery and aeroplanes. These are called turbostarters.
@ PGA, Excellent Posts. I think the Ones used in Earth bound machinery are called Super Chargers and use an engine operated piston compressor to store air in a seperate cylinder which is useful in starting as well as providing optimum intake pressure regardless of engine RPM. Piston powered aircraft also had super chargers but to save on cylinder weights they used explosive caps attached to intakes for starting on ground. Modern piston aircraft have starter motors and fire up only one cylinder, which then fires up rest of the engine.
SR71A is offline   Reply With Quote
Old 10th September 2012, 21:03   #117
PGA
Thanked: 191 Times
Thanks for the appreciation SR71A.
You are quite right about percussion caps firing to ignite the aviation engines of yore.
Superchargers are akin to turbochargers for the purpose they are meant for but mode of operation varies. Superchargers have almost given way to turbochargers nowadays.
Aviation technology of 70 and 80s has come into cars in last decade or so. Driven by severe emission norms of various goverments, engines have to be run more and more efficiently. Thus comes a need to govern them more efficiently which is beyond the capacity of open loop mechanical systems. Therefore you have microprocessor based ECUs. They are not full authority as yet but to meet the norms of near future they would need to evolve very fast to available technological standards. Even today you have ECUs fitted on Indian cars which can dynamically control valve timings, ignition timing, mass flow rates and some more engine governing inputs.
BTW your handle reminds me of one of my favourite machines, the Lockheed Blackbird. One of the greatest machines ever built.
PGA is offline   Reply With Quote
Old 11th September 2012, 12:56   #118
SR71A's Avatar
Thanked: 72 Times
@ PGA ; Though Off Topic, SR71A is indeed the nomenclature used by Lockheed Aircraft for the legendary Blackbird. One of my favourite aircrafts among many
Again on topic. It will be some time before we see FADEC on day to day automobiles. But it will be great if run of the mill ECUs can be programmed to take care of weather extremities.
Again after going through the thread it is apparent that the problem is experienced by only a few types of vehicles and that too not by all the users under similar conditions.
I have been informed that sometimes ECU software will get "stuck" on an erroneous map due to some software error. (These programs are not more advanced than MS Windows!). I have tried to get over the problem by insisting on a reset of ECU to factory settings on all my service visits for my swift DDis. I dont know whether it is advisable for all, but that is one thing that can be tried.
Happy MOtoring.
SR71A is offline   (2) Thanks Reply With Quote
Old 11th September 2012, 20:08   #119
Thanked: 1,078 Times
I have personally not faced any cold start issues, but I do use a diesel antigel product in high-altitude low-temp regions. Hate working too hard to start an engine, if preemptive measures can be taken to ease such efforts.
Here is my take.
At higher altitude, with lower atmospheric pressure, the waxes in the diesel fuel tend to precipitate in cold weather. So there is less fuel going into the cylinders initially (may be due to congestion in the line/filter), after a few cranks there is sufficient fuel to start the combustion. The fuel line clogging must be miniscule and would get cleared once the line is constantly pumping fuel.
That may be the reason that the antigel ensures an instant start.
As far as Laura starting, they for all you know; have designed the fuel lines/filters for European low temperatures, which can regularly hit -30 degrees in winter, sufficient to play havoc if the wax clogs up narrow passages. Just my guess. Some one who has studied the fuel delivery systems in WV and Indian cars can comment on it with more authority.
Old 11th September 2012, 20:14   #120
shankar.balan's Avatar
Thanked: 5,349 Times
Originally Posted by Aroy
Here is my take.
Ooty is not really high altitude in terms of location but for what it is worth, my Yeti started first crank the other day after sitting out in the cold all night. It was switched off and outside from 930pm to 9am. The temperature that night was about 7 degrees at its lowest ebb. Anyway it was cold enough to warrant a roaring fire in our room.
I don't think that a car designed for European cold temperatures will have any trouble handling our scenarios here, except maybe in the depths of winter in the Himalayas somewhere.
National Rail Museum - Matheran Rail Car ATUL SINGH Pre-War 44 23rd August 2017 17:03
Rail Budget 2016: Chennai to get India's first rail auto hub S2!!! Commercial Vehicles 3 22nd May 2016 23:54
Scorpio morning-start problem at high altitudes anupmathur Technical Stuff 105 6th December 2012 09:16
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
TATA indica / indigo with Common Rail engines. hell_rider The Indian Car Scene 2 8th June 2005 10:57
