Old 11th September 2012, 20:35   #121
Thanked: 2,403 Times
Default Re: Common Rail : Why is cold start tougher at higher altitudes
sufficient to play havoc if the wax clogs up narrow passages.
Any form of precipitate chokes the filters. These filters are on the suction side, so you really can't force fuel through them.
Sutripta
Old 11th September 2012, 21:25   #122
Thanked: 420 Times
Ooty is not really high altitude in terms of location but for what it is worth, my Yeti started first crank the other day after sitting out in the cold all night. It was switched off and outside from 930pm to 9am. The temperature that night was about 7 degrees at its lowest ebb. Anyway it was cold enough to warrant a roaring fire in our room.
I don't think that a car designed for European cold temperatures will have any trouble handling our scenarios here, except maybe in the depths of winter in the Himalayas somewhere.
Neither ooty can be called cold
Night temp drops to 0 and -1 in plains in north at many places and summer peak temp is above 45 at same location
Few examples which I can recall are Pathankot Sri ganganagar adampur kota Amritsar Gwalior etc.
There is no start trouble for modern diesels there except for old Amby with shot glow plugs and weak battery.
Sorry for punctuations typing in a mobile browser.
amitk26 is offline   Reply With Quote
Old 12th September 2012, 10:13   #123
SR71A's Avatar
Thanked: 72 Times
All High altitude areas get Winter grade Diesel, which is a blend of regular Diesel with ATF/ Kerosene cut. During winters all of North, Central, North east get winter grade Diesel, with a Maximum pour point of 3 C. However actual pour point is in the range of -6 to -15 C. The cloud point spec for such fuel, when the dissolved wax starts crystallizing is max 6C, actually it may be around 0 to -6C. Fuel generally should not be a problem. Most fuel lines are nylon and tanks are fibre, which is sufficient insulation to keep the fuel well above cloud and pour points.
With little application of glow plugs and few cranks most cars should start.
For Extreme cold weathers where only Military vehicles are plying they get a special grade of diesel which is mostly ATF. Also Russian Military & US Army run exclusively on JP5, which is also an aviation fuel and a Kerosene cut.
If your car is not starting in in cold weather upto -15C then the problem may be mechanical rather than with fuel. Some Fuel lines may be poorly designed with sharp bends which tend to accumulate wax. Exposed metal lines are more prone to waxing and clogging.
Regards.
SR71A is offline   Reply With Quote
Old 13th September 2012, 15:29   #124
Thanked: 1,078 Times
Sutripta
Regards.
I think that SR71A has a point - badly designed fuel lines will accumulate waxes
Old 13th September 2012, 19:37   #125
SS-Traveller's Avatar
Thanked: 11,628 Times
You mean something like atherosclerosis in the human circulatory system? Wouldn't this clog fuel supply even when the engine is at running temperature?
Old 13th September 2012, 19:55   #126
When the engine is running, the fuel keeps circulating in a closed loop under pressure, so small amounts of wax will just be pushed out; and even dissolve; as the flowing fuel would heat up marginally initially and quite a bit after some time. In case the car runs rough for the first few minutes, this corroborates the hypothesis.
When the car is stationary, the wax may just about constrict the passage, so less fuel will be going in.
Again as this happens only at high altitudes, coupled with the fact that it does not occur when anti gel is used, wax precipitating at low atmospheric pressure seems, to me, a plausible reasoning. To verify if this the correct diagnosis, carry the antigel, see if there is a starting problem in the morning, add the anti gel after the car starts and then test it next day. If no problem then it is gelling, else we are back to square one
Old 13th September 2012, 20:06   #127
...small amounts of wax will just be pushed out; and even dissolve...
With a stationary car (engine off), at any particular point in the fuel line, one can only expect 1-2 ml of fuel to remain. How much of wax will it deposit out, to clog the line during cold start? As to the fuel gelling in the whole fuel line, I would think that is a different issue altogether, and gelling will happen irrespective of the design of the fuel lines - and an antigel will sort out the matter.
It is not as if a fuel line with lots of sharp bends will promote higher gelling of the fuel as a whole - IMO the bends may promote deposition of wax "plaques", constricting the flow, in which case operating the engine at any temperature at all will starve it of fuel.
Old 13th September 2012, 20:56   #128
I think we should start another thread on starting diesels when cold. Because I think the focus of this thread was to be CRDIs and high altitudes.
Regarding choking, it is like a chain. The weakest link will be the first to fail. IMO, it will be the filter.
The orifice in a CRDI injector are incredibly small. The pipes/ rail cross sectional area is 1000s of times larger.
Sutripta
PS: SS- are you thinking of stents and bypasses now?
Old 13th September 2012, 20:59   #129
No, just balloon angioplasty!
Old 14th September 2012, 11:36   #130
SR71A's Avatar
Thanked: 72 Times
Gelling beyond pour point, when the fuel will not flow freely will happen across the fuel system regardless of design. The design becomes important at temperature range between Cloud Point (when wax starts to crystallise) and Pour Point (When Fuel stops flowing, though still not completely solid)
A sharp bend will create a trap for the wax crystals when the fuel temperature is below cloud point but above pour point. Whereas a straighter line will allow the fuel to flow relatively freely even if slightly waxed. Above cloud point fuel is completely liquid and will not deposit any wax. As fuel warms up due to warmer fuel returning via return line, the clouding will reduce and thereby the clogging.
Once the fuel reaches below Pour point only external heating works.
Most people who travel to High altitude areas carry substantial quantity of plains Diesel in their tanks, which clouds at much higher temperatures.
Since most car engines these days are CRDI, it can safely be assumed that we are talking about majority of Diesel cars.
Additive added to fuel before going to cold areas should work. Adding them to fuel tank after the fuel Clouds over may not be of much use.
SR71A is offline   (1) Thanks Reply With Quote
Old 14th September 2012, 16:20   #131
You have put; what I wanted to say; succinctly.
In past, have seen drivers of diesel Ambassadors, lighting fire under the sump before they start the car in the morning, after a heavy snow fall. So cold (resulting in highly viscous fuel) did affect non CRDI cars also.
Old 15th September 2012, 04:09   #132
Thanked: 317 Times
Tangential to the above - how badly does cold affect lubricants?
vina is offline   Reply With Quote
Old 15th September 2012, 14:58   #133
SR71A's Avatar
Thanked: 72 Times
@ Vina. Engine oil also undergoes similar gelling and freezing process in cold. Suitability of engine oil for a particular ambient temperature range can easily be sourced from the internet.
If the oil freezes the engine may still start but the oil will not circulate as the pump will not be able to push it to all the nooks and crannies resulting in engine failure.
Most common grades ambient temperature ratings are given below.
20W40 is suitable from -6.7 to 40C
10W40 from -17.8 to 40C
5W40 From -29 to 40C
Regards.
Old 15th September 2012, 19:37   #134
Cold affects all fluids. It just depends on their freezing point. Heavy oil thicken faster, unless viscosity modifier is used. So you may have a situation where the engine oil has become extremely viscous and the gear oil has jammed the GB, not to talk of the differential which has a more viscous formulation.
Fuels also freeze, diesel much before petrol. When they heated the Ambassador's sump, they were heating fuel pump also.
Old 15th September 2012, 20:55   #135
Thanked: 317 Times
Regards.
Thanks SR71 and Aroy, I do understand that all fluids will eventually freeze at low temp. but was not aware of whether engine oil can be a problem too (apart from diesel itself)
National Rail Museum - Matheran Rail Car ATUL SINGH Pre-War 44 23rd August 2017 17:03
Rail Budget 2016: Chennai to get India's first rail auto hub S2!!! Commercial Vehicles 3 22nd May 2016 23:54
Scorpio morning-start problem at high altitudes anupmathur Technical Stuff 105 6th December 2012 09:16
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
TATA indica / indigo with Common Rail engines. hell_rider The Indian Car Scene 2 8th June 2005 10:57
