Old 19th November 2015, 00:12   #16
Thanked: 463 Times
Default re: Stripped screws : whats your way of dealing with them?
Hi all,
Today, I planned to change the transmission oil in my Mahindra Duro. There is a gearbox between the CVT and the rear wheel. It has an oil filling cum level plug (which is a screw) and an oil drain plug (which is also a screw). Both these need 10 mm spanner to open.
Both of them were so tight that they did not move at all with ordinary spanner. When I used a longer tomy bar with the spanner, the screw head just got rounded. I even tried with a box spanner but no use.
Can anyone suggest me an easy way to take out the screws?
Rahul Bhalgat is offline   Reply With Quote
Old 19th November 2015, 08:42   #17
lurker's Avatar
Thanked: 678 Times
are turning towards the right side. First ensure that .. once that is clear
1. You have to heat the screw with a blow torch .. not too much but just enough. The heat will expand the thread and then when it slightly cools down there will be slight gap. This is the time you should use your extension bar and remove screw.
2. You can use special tools which have special teeth to open stuck bolts. But I doubt if these are commonly available.
lurker is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 08:52   #18
PatchyBoy's Avatar
Thanked: 1,397 Times
Use a vice grip.
Stripped screws : whats your way of dealing with them?-vicegrip.jpg
PatchyBoy is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 09:43   #19
kavensri's Avatar
Thanked: 118 Times
Default Re: Stripped screws : whats your way of dealing with them?
Hi all,
Recently I faced similiar issue while removing one of the tyre from my car. When I brought the alloys, the lug nuts that were put to fix those alloys were of very bad quality it seems. Luckily my car was in a garage at that time (to replace old tyres). So, the garage fellow had to take my car to the nearby welding shop, welded a T joint to that particular nut and used his tool to remove it. I am not sure whether it is so bad in your case, but just thought of sharing my experience.
kavensri is online now   (1) Thanks Reply With Quote
Old 19th November 2015, 10:23   #20
Thanked: 1,083 Times
If the bolt is accessible, then use the bolt extractor. I bought this over 40 years ago, but it should be available in any large hand tool shop.
Stripped screws : whats your way of dealing with them?-hsc_6562.jpg
Stripped screws : whats your way of dealing with them?-hsc_6563.jpg
Stripped screws : whats your way of dealing with them?-hsc_6564.jpg
The square socket takes any 1/2 inch drive socket accessory - ratchet, T Handle etc. The knurled knob will grip the bolt head so that it can be turned.
I suggest that to prevent further damage, you use WD40 to loosen the jammed threads, before any other action
Aroy is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 10:26   #21
Thanked: 463 Times
[quote=PatchyBoy;3850958]Use a vice grip.
Thanks lurker, PatchyBoy and kavensri.
Yesterday after I went to the bed, I noticed that I was trying to open the screws when the transmission case was hot. I felt trying in cold condition. I immediately got up and gave it a try.
Also, this time, I used another box spanner I had, of the same size.
And it worked ! I opened the plugs and changed the oil. Fitted back the plugs and tightened carefully. Will get new plugs in a day or two and put them on the scooter.
Old 19th November 2015, 10:28   #22
lurker's Avatar
Thanked: 678 Times
if it is too stripped, you may even have to weld a 10mm socket to the bolt and then take it off. If your bolt is jammed and head is beginning to get rounded, even WD40 may not help.
nice that you managed to remove it.
lurker is offline   Reply With Quote
Old 19th November 2015, 10:41   #23
::CMS::'s Avatar
Thanked: 470 Times
I would have soldered a small metal piece or another screw head on top of that screw. It can be easily unscrewed then after.
::CMS:: is offline   Reply With Quote
Rotor Screws: Necessary or Not? Chetan_Rao Technical Stuff 2 19th June 2018 12:58
Whats double clutching & whats the reason to use it _Crazi4Speed_ Technical Stuff 109 25th February 2016 08:49
Mistakes while offroading: List them and Learn from them Tejas@perioimpl 4x4 Excursions 38 11th February 2015 16:55
Paintings: Overrated, or do you appreciate them? How much would you pay for them? e1t1bet Shifting gears 17 24th March 2010 14:35
Dealing with wild animals during your road trip Spinnerr Street Experiences 4 7th April 2009 07:22
