Thread Tools
Old 24th May 2006, 14:30   #31 (permalink)
Originally Posted by panky12345
any inputs on deisel --> CNG conversion. Ok it doesnt affect much in MPFI petrol but wass up for deisel?
Converting a diesel into CNG is a lot more complicated and I don't think is worth the effort. It does not make any economic sense also. In Delhi, the entire bus fleet was converted to CNG not for any economic reason but because of the Supreme Court order which could not be disobeyed. As it is, diesel is some 33% cheaper than petrol and on top of it, the diesel engine is inherently more efficient than petrol by about 33%. So, compared to a petrol engine, you are already 66% better off. (Guys, pardon my arithmatic if it's wrong!)
directinjection is offline   Reply With Quote
Old 24th May 2006, 15:22   #32 (permalink)
Hi zappo
Yeah the fuel economy increased. LPG tuning should be taken seriously. I see lots of people who just use it as a cost saving factor. Infact with proper tuning u can get best results. As LPg does not heat ur engine much in stalled traffics u can get good ac output in carb cars. In my case i have changed the electricals of the car. Put in different relays for fogs, horns and Ac. And that surely helps. With petrol my gypsy in city gives me a average of about 10-11 though i cannot be pretty sure about it. LPG tends to give u low average in initial stages as u get used to gearing with it , improvements are seen. Also visit a LPG expert every 3 monts to check gas flow pressure if u constantly switch between petrol and LPG. I will put up another thread oh the exact costs of reoing my Gypsy with LPG A?C and change of electricals if someone can guide me under which forukm i have to post
lodhra is offline   Reply With Quote
Old 25th May 2006, 00:25   #33 (permalink)
gr8guzzler's Avatar
I recently got my Ikon converted and gearing while on gas is a bit different. i was thinking the tuning was not right or something. My engine revvs a bit more when I press the clutch to change gears and the same does not happen when I'm running purely on petrol. Is this what you were referring to?
Also since you are in Mumbai, can you let me know where you got your kit tuned, I would like to get the same done too.
Finally...you can start a new thread under Modifications if you want to provide more details...
Cheers!!!
__________________
Kishore
gr8guzzler is offline   Reply With Quote
Old 25th May 2006, 14:25   #34 (permalink)
Hi gr8
I was given the opinion that the car does not knock in LPG hence maybe u are experiencing the rev up situation. Initially i too got the same problem. I think its just our perception of the car since we have been driving so long with petrol , LPG mode suddenly takes us by surprise. But surely as you experiment it becomes much easier. I did my car at Suman auto LPg which is at link road goregaon. He has his website too http://cng-lpg-conversion.com/
Thank you for the advice will soon post the thread.
Old 19th August 2006, 01:33   #35 (permalink)
Guys pls tell......
Lets say i got my car converted to LPG/CNG, either of them. Now imagine my gas is over while running and due to some reason i am not able to fill it. Then i run on petrol. BEcause the tuning is done to suit the LPG or CNG kit will i get VERY poor FE if i drive on petrol. SAy before conversion FE with petrol is 10/Lt. Will it go down drastically if run on petrol after getting the either Kit installed ?
jdutt is offline   Reply With Quote
Old 19th August 2006, 22:30   #36 (permalink)
wolfinstein's Avatar
@ Jdutt, The engine tuning and engine settings remain the same...! The setting for CNG or LPG are done at the Reducer end or the section where the pipes are connecting into the throttle..! My XETA runs same..! Petrol or CNG. The FE is same 11 Kmpl on Petrol and 16-17 on CNG..!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 20th August 2006, 21:15   #37 (permalink)
Default Thx
That solves one of my worries..........Wolf, do you seen ANY ANY ANY drop in engine response and power (Used 3 times any to be very specific) when u drive with CNG and whats your top speed with CNG ?
How does Xeta behaves with switching ON a/c while running on gas ? Any sluggish experianced....
Old 20th August 2006, 23:00   #38 (permalink)
All right intial drop in lower gears yes...! I cruise on 80 with AC on 5th..! During traffic times I need to shift into lower gears for a stop and go pickup, however while moving shift into a 3 is sufficient to pick on...! Top speed I clocked with CNG mode and with AC was 100 km...on Noida-Fortis road...! You can get the exact details from my review..!
AC ke saath no performance change in 3/4/5 Gear considering you are above 50 Km..! However if you're in lower speeds Car feels heavier..!
__________________
Old 20th August 2006, 23:57   #39 (permalink)
Default Hmm
Not boasting about anything........my TOP speed with petrol 155 Kmph at Noida toll road.
By the way where i can see your review ?
Regards.
Old 21st August 2006, 15:19   #40 (permalink)
esteem_lover's Avatar
so i guess, if the driver is 34% more efficient, then the diesel car would be 100% better off than the petrol one , eh ? its not arithmetic, it is fantasticmetic.
__________________
Advertisements contain the only truths to be relied on in a newspaper. - Mark Twain
Old 21st August 2006, 16:43   #41 (permalink)
ess_a's Avatar
You are actually 50% better off in this scenario!! not 66%....
Ok now i also have a question.... Is CNG good for an Alto.... It is already underpowered especially when the A/C is on.... Do u guys think there wont be a significant loss of power.... secondly what cylinder size should i be fitting if at all i go for CNG???
__________________
The speed of sound is the fastest when some talks in the car, that I am driving...!!
Michael FOREVER...
ess_a is offline   Reply With Quote
Old 9th September 2006, 14:38   #42 (permalink)
ess_a's Avatar
One thing more... Cant euro III cars be retrofitted with CNG kits? The delhi transport authority's site says only cars upto euro II norms can go for the conversion...
Plus does any one know of a good cng intaller in delhi and what kit to go for.... Landi renzo doesnt have kits for euro III cars.... Only Bendini does... Is this true?
__________________
Michael FOREVER...
Old 9th September 2006, 19:34   #43 (permalink)
Don't you know how Goverment Sites work..! Lol
Well it depends on which Euro 3 Car Kits have been approved as of now- TATA, HM,GM Kits are approved...Waise it really does not matter..You can get a new car converted...just that older cars cannot ..Lets say Current Bharat Stage 3,2,1...Legally not prior to that..!
Ya Bedini is Euro 3 ready, You could visit www.iglonline.com and find approved fitters.
__________________
Old 19th September 2006, 17:55   #44 (permalink)
ess_a's Avatar
Checked with Shrimankar in Okhla... The guy said till now the bedini kit they have is not for alto euroIII... He also added that right now the govt has put on hold cng conversions and some new norms are expected to come by 21-22 sept... Now how come if cng kits are available for other euro III cars like xeta and city, they are not for alto? And any review on IMPCO, BRC kits....?
__________________
Michael FOREVER...
Old 19th September 2006, 18:56   #45 (permalink)
spoke with them again, regarding this New Norm and Was advised that it is expected but can't say when..Since the Kits have to be approved by CRI and ARAI ( Or whatever the Transport Authority of India ( Not RTO) is called) that is why the kits for Alto and Palio is yet awaited, However you can go for a older fittment, the only difference with the Euro 3 kit will be an Advanced Lamda Sensor,which you can ask to be installed later when the kits come up.
__________________
Thread Tools
CNG conversion for the Optra? Is it wise? beanstalk_230 The Indian Car Scene!! 10 28th October 2007 20:17
Lancer - CNG conversion... Kinda urgent, Thanks yuv Modifications & Accessories 9 22nd July 2007 13:34
Advice needed:Sedan / Hatchback (CNG/LPG) sandipwadje Hatchbacks 16 3rd May 2007 20:08
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 39 19th April 2007 13:05
CNG conversion Exo Modifications & Accessories 1 29th May 2006 17:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
