Thread Tools
Old 21st January 2007, 22:16   #61 (permalink)
wolfinstein's Avatar
Sudhir, How come you got a full tank of 12 Kg..! I always have to settle for 10.4 kg at Max be it Early morning or Late night..!
BTW the Service Factor as said by you, what does it include, General Check + Leakage Test + Setting or What ?
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 25th February 2007, 12:51   #62 (permalink)
nicejits's Avatar
Infractions: 0/2 (12)
Default CNG/LPG in my 2001 zen
Guys,
I want to install eigther CNG/LPG in my 2001 zen... I stays in Mumbai ,,,plz suggest what shd i get installed i l looking fir more milage as My daily run is 70k
Thx,
JIts
nicejits is offline   Reply With Quote
Old 25th February 2007, 23:47   #63 (permalink)
CNG
1) Running cost will be lower than LPG
2) Power Performance depends on your setting
3) Low Maintainence.
4) Safer than LPG
5) Cost of CNG kit from Nugas/Bedini/Landi Renzo are more expensive than LPG kit but the costs are recoverable in no time with the saving amount.
6) More Mileage than LPG ( LPG gives 1+- compared to petrol, Only thing is its cheaper than Petrol and gives almost same output as Petrol would have. CNG is much greener, Natural Gas leaves slight carbon and Water Vapour as By product- Mileage is Higher with my Xeta I now clock 17 Km per Kg of Gas @ 19.20 per Kg.
You can however read through many threads here on CNG vs LPG to make your mind, However Each as its advantages and Disadvantages- Basic thing to be kept in Mind is Safety / Economy.
With a 70 Km running CNG will cost you around 89.6 ( Considering that you get 15 Km per KG with AC full time on) and with LPG cost will be around 150 ( considering a mileage of 14 Km per Kg)
__________________
Old 27th February 2007, 10:10   #64 (permalink)
nicejits's Avatar
Default I can go only 157.5 km ?? on CNG
Hi wolfinstein ,
Thx for your advice, I guess I will convert my zen on CNG but have small quarries, plz help me to solve those :
1) From lots of thread I cam to know max tank size for CNG is 14 kg, in that you can fill only 10.5 kg, that means if FE of my zen is 15km then after filling tank completely I can go only 157.5 km, is that true ??
2) If I am running car with A.C on, will get CNG smell in cabin ??
plz answer above queries
Thx in advance
JItendra
Old 19th May 2007, 13:01   #65 (permalink)
naveen.kk's Avatar
Infractions: 0/1 (4)
Hi
To EMphasize 1KG of CNG is equal to 1.8 Litres of Petrol. So 10 KG of CNG is almost equalant to 18 Liters of Petrol. simple u l get 250 - 270 KM for 10kg CNG.
but a quick question. Will that 10KG Cylinder let you take your spare tyre out of its place?
Are you fitting any conventional Kit or Sequential kit?
naveen.kk is offline   Reply With Quote
Old 19th May 2007, 20:31   #66 (permalink)
Nobody fits a Conventional kit these days unless they are working on a budget, But a 7000 increase for Lamda-ECU and Timer is worth the performance from conventional kits.
Why Not, If you have Foldable Rear Seats, the Tyre can easily be accessed and interchanged incase of repairs..!
__________________
Old 20th May 2007, 11:18   #67 (permalink)
.anshuman's Avatar
On the power front cng resulted in slight loss of power, but as a fuel its really good for the engine because being a gas there are no deposits left in injectors etc.,(It was MPFI esteem).
But injectors are not used for injection of gas,a mixer is installed on the throttle body to mix gas and air.
pls refer to this link, this my experience with gas conversion. http://www.team-bhp.com/forum/long-t...lpg-cng-2.html (My experiments with LPG and CNG)
__________________
HR 26 X 786
Old 20th May 2007, 21:55   #68 (permalink)
mail4ajo's Avatar
Right, Injectors are supposed to stopped by use of an Emulator. I think he meant carbon deposits in the throttle body.
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 20th May 2007, 23:14   #69 (permalink)
esteem_lover's Avatar
Originally Posted by wolfinstein View Post
CNG
4) Safer than LPG
How is that ?
__________________
R.I.P Islero
Old 21st May 2007, 13:21   #70 (permalink)
Safer Here is why :
1) LPG is Liquified Petroleum Gas which shares all the characteristics of Petrol- It is Inflammable at room temp with any small spark- Just like your regular Home Gas.
2) LPG is heavier than Air, so incase of a leak it settles in the lower sections of the Car or When it leaks in yor house it settles towards the floor.
CNG on the other hand is Methane- Lighter than Air, So incase of a leak, it dissipates in the Air quickly.
With CNG -You either need to compress it or Need a Strong Heat source to spark it up.That is another reason why engine power loss is present in CNG and not in LPG- CNG needs High Ignition.
And then the cost effectiveness is more than LPG- Cleaner Engine, Less Carbon...More mileage than Petrol and Its cost is Rs.19.20 per Kg which gives me 16-17 without AC on My XETA.
Whatever one chooses, They need to ensure a good kit, safety aspect during installation, periodic checks for leaks,Insurance Cover Added and RTO Mandate-these will ensure a safe drive and legal formalities upto date incase of any uneventful incident.
__________________
Old 21st May 2007, 13:40   #71 (permalink)
That should be an advantage not a disadvantage. And talking of leaks, a fuel leak is a fuel leak, petrol, diesel, lpg or cng, it should never happen.
__________________
R.I.P Islero
Old 21st May 2007, 13:46   #72 (permalink)
Well depends on how you love to see your car up in flames with even a slightest leak..!
Incase of a Major Leak, CNG or LPG both can flame up, But CNG being lighter will dissipate as quickly as possible.
Unfortunately, Leakage can happen anytime, that is why I mentioned that its better to have periodic checks done up to isolate and repair any leaks..!
When Comparing CNG and LPG it serves as a disadvantage on Safety factor.
__________________
Old 21st May 2007, 13:55   #73 (permalink)
tsk1979's Avatar
Its is true that if the gas in tanks is lighter than air, it will reduce chances of fire very less.
Due to this reason, hydrogen which is highly inflammable is actually quite safe. Its another matter compressing H2 and storage is very very difficult.
__________________
Reclaiming.....!
Old 29th June 2007, 15:18   #74 (permalink)
naveen.kk's Avatar
ohh god CNG is just 19.20 rupees?
Where is it? Is it in Delhi?
Here in hyderabad it is 30 rupees, even then my runnig cost is 2 Rupees/ KM.
I get 15 KMS in City with A/c and 18-20 / KG of CNG in My palio 1.6
Old 29th June 2007, 16:22   #75 (permalink)
abbey4u's Avatar
Default Advise on CNG convert of Maruti Zen 1995 carb
Hi I have an old maruti Zen carb (1995) and almost ran 65 K Km. I am planning to convert this into CNG. However I have a slight hiccup due to the following queries.
i) Since it almost ran 65 K km. Is it wise to convert it to CNG?
ii) What would be the average % drop in performance? Will it require any specific tuning ?
iii) If I install K&N filters and Iridium spark plugs will it compensate for the loss in performance?
iv) How much more life I should expect from the car after installing CNG?
v) What would be the cost of conversion? I live in NCR region
Would be very grateful if some one take a call to answer these questions.
abbey4u is offline   Reply With Quote
Thread Tools
Sx4 ZXI CNG Conversion/ICE Query kumargandharva Sedans 5 23rd June 2008 12:33
CNG conversion for the Optra? Is it wise? beanstalk_230 The Indian Car Scene!! 10 28th October 2007 20:17
Lancer - CNG conversion... Kinda urgent, Thanks yuv Modifications & Accessories 9 22nd July 2007 13:34
What's your stopping factor on a LPG/CNG conversion Surprise Modifications & Accessories 39 19th April 2007 13:05
CNG conversion Exo Modifications & Accessories 1 29th May 2006 17:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
