Old 29th July 2010, 11:47   #1
tsk1979's Avatar
Thanked: 16,420 Times
Default Teflon Bushes - Where to get them in Delhi
I was told by a member during the noida meet that fitting teflon bushes will take care of the frequent rubber bush crack issue in the Safari.
He told me that a teflon sheet has to be purchased, and cut to size on a lathe.
I am wondering if anybody has gotten this done.
How much is the cost (total cost of sheet, labor and fitting).
any good workshops which do this job?
Old 29th July 2010, 11:51   #2
chiragh_bir's Avatar
Thanked: 70 Times
we deal in special kind of industrial Teflon self lubricating bushes !!!
see this link if it suites ur needs !!!
http://www.techaids.in/images/produc...eeve-roll3.jpg
chiragh_bir is offline   Reply With Quote
Old 29th July 2010, 12:07   #3
tsk1979's Avatar
Thanks Chirag, I would also need a competent workshop to fit these, and also see if the size matches!
Old 29th July 2010, 19:56   #4
Mpower's Avatar
Thanked: 1,687 Times
I was told by a member during the noida meet that fitting teflon bushes will take care of the frequent rubber bush crack issue in the Safari.?
Where? in the suspension control arms?
Teflon rod can also be purchased and its much easier to machine compared to sheet. Check electrical shops (its used for insulation as well)
Old 29th July 2010, 21:23   #5
AbhiJ's Avatar
Thanked: 532 Times
Although the teflon bush will last much longer, it will not give any dampening effect.
A primary function of rubber bushes is also to dampen.
IMO, the ideal solution to you problem would be to get good quality synthetic rubber bushes manufactured.
AbhiJ is offline   Reply With Quote
Old 30th July 2010, 00:27   #6
Thanked: 660 Times
i will not dare play with machined parts on top of factory made recommended specs suspension.
How ever what Chiragji posted can be used.
Mistakes while offroading: List them and Learn from them Tejas@perioimpl 4x4 Excursions 38 11th February 2015 16:55
Paintings: Overrated, or do you appreciate them? How much would you pay for them? e1t1bet Shifting gears 17 24th March 2010 14:35
Press Fitting Urethane Bushes 1self Modifications & Accessories 2 27th February 2010 13:10
Cost of suspension bushes [Gypsy King] khan_sultan Modifications & Accessories 1 20th December 2007 18:24
Polyurathane bushes?? shrivz Technical Stuff 0 10th November 2006 20:40
