Old 1st August 2010, 20:36   #1
Awaiting Email Confirmation
Smile Swapping an automatic gearbox in a Honda city type II VTEC
Hi - I have a VTEC OHC which has done 60K. I want to swap the manual gearbox with an automatic one. I want to know the foll things:
1) Can I do the swap?
2) Which auto box should I use - normal automatic gearbox or CVT?
3) DO I need to change the ECU?
4) Where can I get a good auto gearbox in Mumbai?
5) Is there anything I need to take note of b4 I go ahead?
Karthik
KK396 is offline   Reply With Quote
Old 1st August 2010, 22:07   #2
4x4addict's Avatar
Thanked: 2,669 Times
@Karthick;
The Automatic Transmission ECU and Engine ECU send signals back and forth. So you will definitely need to alter/change the Engine ECU.
Why in gods name would you ruin a VTEC by making it an Auto? I think it will be much better to sell and get an Auto.
4x4addict is offline   Reply With Quote
Old 1st August 2010, 22:26   #3
greenhorn's Avatar
Thanked: 1,519 Times
IIRC someone here had posted their experience of converting an OHC ( not sure if it was a vtec) to an autobox, and it did not end up good.
Old 1st August 2010, 22:49   #4
anku94's Avatar
Thanked: 33 Times
Not that I have any experience, but I strongly advise against doing so. There are some things that can only be done at the manufacturing level, because of the sheer complexity of the 'thing'.
Things are further complicated in modern cars with their ECUs and sensors. You just can't modify them beyond a limit. All the components are made for each other. A mod of this magnitude will, most likely, be a jugaad.
Your signature says you're procuring a 2009 NHC. Why don't go an extra mile and get an A/T car if that's a must for you ?
If it's just the modding bug itching , I'd suggest you unleash this energy on a mod of less complexity.
anku94 is offline   Reply With Quote
Old 1st August 2010, 23:13   #5
pranavt's Avatar
Thanked: 274 Times
Should be easy. Find the corresponding transmission and peripherals and an AT ECU from the City AT. The blocks for both the 1.5 EXI and VTEC are probably the same, so the transmission should bolt up correctly. It will not enable VTEC though, since the CITY AT sold here was a 1.5 EXI. Finally, round it off with the City AT speedo cluster. Find the right garage and it's definitely doable.
Old 1st August 2010, 23:17   #6
Thad E Ginathom's Avatar
Thanked: 8,377 Times
Buy the car you want, or be happy with the car you have.
Mods is one thing, turning it into a different car is another.
Old 1st August 2010, 23:19   #7
pranavt's Avatar
Thanked: 274 Times
What is so difficult about this? The whole thing will probably be a bolt-on job once he procures the required things.
Old 1st August 2010, 23:29   #8
Thanked: 660 Times
Thats will be the main problem, isn't it? In a country where we have to wait for weeks for standard parts to arrive.
i will not advice you to do such a swap.
If you are doing this coz you are tired of shifting in city traffic. You can install semi-auto kit. Cheaper and does the job to some extent.
Old 2nd August 2010, 00:20   #9
How many required things? And what tools/kit/workshop facilities would it need? And how much car to take apart to fit/exchange them? And how much will it rattle when it is put back together? And what to do with the left-over bits? And how easy is it to buy the right car in the first place? How many people here routinely take the engine and or the transmission out of their car and put it back again? Handling that kind of stuff is dangerous for a start. I'm assuming that KK396 is not a trained mechanic --- else he probably wouldn't be asking.
Now... that's a new one on me! what's that?!
Old 2nd August 2010, 01:50   #10
pranavt's Avatar
Thanked: 274 Times
Whatever I have posted in my previous post.
A good garage will have everything. For that matter, any roadside mechanic can open up a transmission. A good one should be able to take apart an automatic transmission if need be. Swapping a transmission wouldn't require opening it.
Assuming you meant money, depends on the cost of the parts. Would be less than selling this one and/or buying a new car with an AT gearbox.
If done at a good garage, probably not at all.
That is his problem. Finding a buyer wouldn't be impossible.
I believe he already has the car.
Including mechanics, thousands in Mumbai alone.
By that logic, everyone on Team BHP who has a good amount of knowledge about cars is a trained mechanic.
Old 2nd August 2010, 01:59   #11
Ahhh... I was, somehow, thinking he intended to do it himself. Sorry if my misunderstanding wasted your time.
I still think it's a bad idea --- but, sure, getting it done by competent mechanics could put a different slant on it.
Old 2nd August 2010, 11:17   #12
Abes's Avatar
Thanked: 57 Times
I have seen people replacing AT with MT, when AT starts having problems. Not seen anyone doing the opposite. Though it might be possible with the right mechanic, as stated by Mr. Thad.
Abes is offline   Reply With Quote
Old 2nd August 2010, 11:57   #13
rohan_iitr's Avatar
Thanked: 412 Times
I think the thread title is misleading.
I thought that he was trying to replace AT with MT.
Rohan
rohan_iitr is offline   Reply With Quote
Old 2nd August 2010, 12:14   #14
The OHC is my 2nd car - already got a manual ANHC, which my wife is using and is driven by a driver
Like Pranavt mentioned, cost implication - its cheaper to convert to an auto than buy a new one.
Old 2nd August 2010, 15:21   #15
Thanked: 660 Times
Semi automatic/auto cutch is a bolt on kit that can be fitted in any vehicle.
I think there is even an Indian manufacturer. I remember seeing one in an auto magazine long ago.
more info
http://semiautomaticar.blogspot.com/
Problematic- 2003 honda city automatic gearbox stormsearcher Technical Stuff 16 8th April 2013 01:56
Max top speeds on Type 2 Honda City VTEC President Technical Stuff 3 11th February 2008 11:21
