Old 3rd August 2010, 20:42   #1
EFF-EIGHT-BEE's Avatar
Thanked: 96 Times
Default Gear linkage glitch !
Hello fellow bhpians. I got a 97 make m-800. While coming back from college today i found difficulty in engaging 1st and 2nd gear. On returning home i found that the gear liver in neutral instead of being in center it was in left side where 1st and 2nd gears are. Also if 3rd and 4th gears are selected the liver gives a look as if 3rd and 4th gear(respectively) is engaged. I suspect busted ruber bushe in gear linkage. I will be taking her to MASS in tomorrow, please give your valueable inputs before i take her tomorrow.
MODS: Sorry for long post.
EFF-EIGHT-BEE is offline   Reply With Quote
Old 3rd August 2010, 22:26   #2
Thanked: 96 Times
A little correction here, the gear liver looks like as if 1st n 2nd gears are selected when actually 3rd n 4th are selected.
Old 3rd August 2010, 23:08   #3
Thanked: 658 Times
You may have to replace the gear lever kit. Its a mixture of plastic and rubber parts. Not that expensive.
Also replace a small plastic linkage between two link rods. Its lies below the car.
DIY: Replacing the Wiper Linkage on a 1st-gen Honda City One:1 DIY - Do it yourself 3 11th May 2016 17:30
Engine jerk/glitch Abhay Technical Stuff 24 10th December 2015 13:28
How long does take to change the wiper linkage - 4 hours!!!! amtak Indian Car Dealerships 2 6th July 2009 11:28
glitch with number of posts. heelntoe Shifting gears 1 3rd May 2006 00:06
And so it happens...First electronic glitch in the C220 GTO Technical Stuff 30 4th April 2006 22:16
