Old 4th August 2010, 19:53   #1
Default Noise while accelerating Punto 1.4
I have been getting this high noise(like auto ?) from my punto 1.4 while accelerating (second service onwards )
While taking that video, the rpm was always below 3k rpm. Tata and Fiat guys tried to find the issue many times, but they have been unable to find it so far. They are now blaming it(they call it knocking noise) on bad fuel which is not the case since I didn't refill petrol between second service and the first occurrence of this noise. Also I tried changing fuel (from IOL to Shell ) and the issue persists. Appreciate if someone can provide some idea on the possible reasons for this issue
Sujai is offline   Reply With Quote
Old 4th August 2010, 21:11   #2
vigsom's Avatar
Thanked: 604 Times
It is diffucult to figure out the noise 'coz the video has been filmed from inside the car.How many kms has the car done?
You could check the following:
  1. Do you feel a drop in pick up and some sort of chugging sound?If yes,one of your plugs is not firing.
  2. Check if the oil level is normal(engine to be shut off and level to be checked only after ,say,10 minutes).
  3. If oil level is normal,open bonnet.Start engine and check if you hear some sort of clatter.If yes,your tappets need to be set.
Old 5th August 2010, 11:26   #3
1. No drop in pick up
2. Oil level is normal
3. Not able to hear that also
10,000 kms on odo
Old 5th August 2010, 13:01   #4
bottle's Avatar
Thanked: 138 Times
could hear it knocking at the start of the video, a friend of mine had knocking problems in his linea and it improved when he tried speed97 from a reputed bunk . maybe drain the fuel in the tank and get it cleaned and try
bottle is offline   Reply With Quote
Old 23rd August 2010, 19:14   #5
Not sure what the service center guys did :(. I am uploading one more video with better video and sound
Old 25th August 2010, 19:28   #6
Can someone pls provide some ideas on what could be causing this noise ? :(
Old 7th December 2010, 22:52   #7
vsk2009's Avatar
Thanked: 23 Times
Are you still facing the problem? I am not able to hear your recording clearly. But one thing I have noticed in my car(1.4GP) is that it is silent while idling and when accelerate , especially in 1,2 gears it gives a very unrefined feeling. Once it cross 60 km/h in higher gear it is smooth till 3000 rpm mark. After that I haven't tried since mine is a new car.
vsk2009 is offline   Reply With Quote
Car jerking while accelerating adya33 Technical Stuff 32 24th May 2017 07:56
VW Jetta TDI - noise while accelerating aghosht Technical Stuff 1 3rd August 2012 16:26
Squeeking sound while accelerating. Need remedy. Torque123 Technical Stuff 14 2nd November 2009 19:31
Maruti 800 - Rattling Noise When Accelerating ashwinsid Technical Stuff 13 18th May 2009 14:39
Brake warning light comes on while accelerating bottle Technical Stuff 12 22nd December 2008 23:40
