Thread Tools
Old 18th November 2005, 12:25   #1 (permalink)
sajo's Avatar
Default Need Tips for restoring M800.
I didnt know where to post this, so I posted it here...
We have a 1993 M800, which has done around 75000 kms.The trouble is, 74k+ kms were done before Aug 2000. Then we got an Indica2000 , and this one was garaged. It has been driven very few times since, but always for short distances.Its now somewhat of a rustbucket. Since last year, we did undertake a few half hearted efforts to work on it, but the were umm...half hearted.
The following things were replaced in various stages last year -
1.Battery . (had gone dead in 4 years)
2.Head gasket (it blew once because the coolant somehow leaked off, we were stuck once on Karve Road with steam coming out from the hood).
3.Brakes.
4.Accelerator pedal was stuck to the floor. (Full revs all the time). It was fixed too.
Every now and then, I get all fired up and decide to drive it more, but I never do.(I prefer to use the bike, and dad his other car).
I tried to start it today (first time since June), and it did start after a few cranks.A few things I noticed were -
- Creaking doors. (Pune Monsoons were not kind this year).
- Seat recliner jammed! I had to sit in a position too upright for comfort.
- Wheezing noise coming from the engine,like air is leaking off somewhere, while revving. I have posted this sound I recorded using my phone. Its not too clear, but still..
- Door trim peeling off. Dashboard colour is fading.
- Brakes have become rock hard.
- A/C switch went all the way in when pressed. (BTW, the aircon still works, ineffective though it is.)
Can anyone suggest what things to look out for if it is to be brought back to its original state? Is it possible in the first place,after remaining idle for so long? I dont want to spend too much money.
This is the whooshing sound I am talking about.
http://rapidshare.de/files/7793195/rev2.wav.html
This is a pic of the car (cam phone quality..sorry).
This is the ultra upright seating position.. Its now stuck there. :(
__________________
Its big, slow, thirsty and American - but love is strange!
sajo is offline   Reply With Quote
Old 18th November 2005, 14:19   #2 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Unless this car has high sentimental value, its better to dispose it off, as you will spend close to 20-30K to restore it.
I know about a 1990 model 800 which was partially restored
Overhaul done at 120000kms (Full engine overhaul)
Interiors and gearbox suspension, body anti rust etc., etc.,
Total cost was 30K, and still results are not that good. Unless you know a very very good mechanic its a waste of money and time.
However if you do find one here's the best way to start, but beware it will be a very expensive excerisise. 4 years of no use wrecks are car much more than 4 years of abuse
1. Electrical system.
As such 800 electricals are reliable, but m800 has a very bad feature. the flimsy wires near the tail lights area which tend to short and all. Get them all replaced
2. Fuel pump and fuel delivery
This is the toughest part and you need an excellent mechanic to do so.
3. Suspention and brake pads and steering
All bushkits have to be replaced. Along with the brake pads. Add to that the steering bushes
M800 is full of these rubber bushes(Atleast the old ones had them) which would require replacement every 8000kms or so if used in rough road conditions
Not only that wheel bearing would have to replaced if they are not new
__________________
Reclaiming.....!
Old 18th November 2005, 19:00   #3 (permalink)
sajo's Avatar
This car does have sentimental value attached to it, but not too much so. If we sell this car, we would get quite a negligible price for it (inspite of the special registration no. which I understand holds religious significance for certain communities). So I might as well use it while there is still life left in it.
Thankfully, all electricals are working. Except the engine temperature indicator, if you call that an electrical. Even the lousy old stereo was working. I dont think a full overhaul is needed yet, because inspite of the whooshing sound, it does rev pretty cleanly. But I am no expert to comment in these matters, and will be grateful if someone does. The more I think about it, the more I want to bring it back to useable condition.
__________________
Old 18th November 2005, 20:15   #4 (permalink)
Team-BHP Moderator
tsk1979's Avatar
If so then show it to a good mechanic. By good I mean really good. Ask people around, and see the workshops. DO NOT go to maruti authorized service center. They will cost you a bomb.
__________________
Reclaiming.....!
Old 18th November 2005, 22:08   #5 (permalink)
airfoil's Avatar
If I were you, I'd sell the car - it will turn into a liability given a short period of time. Sell it while you still can get something for it rather than spend on restoring it. This goes double considering the car has seen a thousand kilometers in five years. If this rate of useage is expected to continue, then its best to get rid of it.
If you do decide to keep the car, then go about the restoration piecemeal - concentrate on one area at a time, restore it and move on to the next, once you're satisfied that that the job is well done.
Good luck!
airfoil is offline   Reply With Quote
Old 19th November 2005, 01:49   #6 (permalink)
ThE_DoN's Avatar
Jus one question.. How come your battery had juice left in it to crank up after 5 months !!!!!!
Mine goes weak if i dont start the car for like 2 weeks or so.. (M800)
OTHERS pls clarify i got a new 1 month old battery.. ??
I use my car only once or twice a week for around 20 kms..
sorry goin goin off-topic
ThE_DoN is offline   Reply With Quote
Old 19th November 2005, 02:18   #7 (permalink)
I have heard someone say something similar about a battery. They take the leads off, so they say there is no drain on the battery and they claim their vehicle cranks up after 4 months.
bigman is offline   Reply With Quote
Old 19th November 2005, 08:13   #8 (permalink)
sajo's Avatar
I dont know how it did (touch wood). But it did require a few cranks before starting. After taking its time to warm up (it vibrates like hell during that time), it settled down after a couple of minutes of idling. The vibrations at idle mostly disappear after a few minutes.
__________________
Old 20th November 2005, 14:29   #9 (permalink)
ThE_DoN's Avatar
There is no replacement for displacement
Old 6th April 2006, 19:36   #10 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
sajo, you still have this car and still plan to bring it back to life.
Asking because Edmund has a thread where he details the restoration of his 85 model M800. And he is at Pune too. You could check with him about the mechanic and glean some info from that thread too - he has done a neat job of restoration.
bigman, what you heard is true. When not using the car for sometime, say a week or more, just disconnect one of the battery terminals. This will retain the battery charge. I do it always when I have to go out of town for a week or more.
__________________
Give time a break - be a part of the Chennai-tbhp drive to Pondy.
Check out the "Rendez-vouz at Pondichery" thread for details.
Old 6th April 2006, 20:59   #11 (permalink)
Team-BHP Moderator
adya33's Avatar
Sajo, PM Edmund. He will be of great help.
I will call you later regarding this topic.
adya33 is offline   Reply With Quote
Old 6th April 2006, 21:20   #12 (permalink)
sajo's Avatar
Ahh..actually, it was restored around the same time as this thread was posted (or about a week after that). The list of jobs he had done was big, and the bill ran for about 3 pages. The total cost? Rs.2200. It was running fine, until recently, it blew the fuel pump :(.I think far too much of poor quality fuel filled from any pump in its 14 year lifespan did it.. I had to jerk my way home for about a km or so... And stalled about 20 times (No mechanic since it was about 9 in the night). Plan to get that repaired once my submissions are over by next week.
__________________
Thread Tools
Restoring a Morris khanak Technical Stuff 11 11th June 2008 16:13
Restoring a 1991 Fiat adheesh Modifications & Accessories 14 26th October 2007 12:11
Restoring Alloy wheels? GTO Tyre & Alloy wheel Section 15 10th March 2006 04:17
Restoring a Plymouth 1956 moralfibre The Indian Car Scene!! 1 26th November 2005 11:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
