Old 16th August 2010, 11:07   #16
johnruben's Avatar
Thanked: 74 Times
Autocop guy came last saturday and fixed my sensor issue and then when i asked him to resolve the doors being unlocked when switching off the engine, he said its by default, then i told him, it doesnt happen on my swift unless i remove the keys, for that he told he can configure in such a way, that at accessory switching mode he can program this to unlock door and not when we switch off the engine, i said ok and do it, for that he told he needs to remove all cables and lot of work and i was busy that day so told him to come another day.
so girishbhat, you can solve this problem by programming your security device to unlock doors at accessory switch mode thereby it wont unlock the doors even if u switch off the engine.
Good luck
johnruben is offline   Reply With Quote
Old 16th August 2010, 11:54   #17
Awaiting Email Confirmation
@JustCause: My nippon remote is same as this.
http://www.team-bhp.com/forum/attach...0042009244.jpg
@johnruben: Thanks for the info.
girishbhat is offline   Reply With Quote
Old 16th August 2010, 15:58   #18
CPH
Thanked: 34 Times
Originally Posted by Googleman View Post
Well there are lots of answers for this. It is dangerous in case of an accident and the electricals fail.
Wonder why all 4 power windows is not suggested? Why would they design it the way it is? why wouldn't they manufacturers allow the doors to be locked throughtout? I suppose before bringing a product they do a lot of research and tests.
Anyways, there can be a long debate on this. I just gave an advice, it is up to people to take it or not.
+1
@ girishbhat - I would like to add that in case of a fire time is of the essence. If you end up in accident, where you are unconscious and the car catches fire and people need to smash windows first to get to help then you hardly stand a chance.
Also switching off the engine at every traffic light is not saving you any fuel unless it is quite long periods. Additionally it wears out quicker the starter motor.
CPH is offline   Reply With Quote
Old 16th August 2010, 23:19   #19
Thanked: 1,440 Times
I had a Maruti 800 with Nippon central locking installed, and now have a Santro Xing with the Cobra central locking installed. Both systems are a little different, as in the Maruti, the driver side lock operates all the door locks, while in the Santro the driver side lock does not operate any other door locks.
With the Maruti when I had to switch off the engine at signals, I would turn off the ignition and then simply lock the driver side door, so all doors stayed locked. With the Santro, I switch off the engine and then switch back to ignition on position quickly. This way the doors never get unlocked. The only downside is the ignition has to be on, but if you can turn off all the other electrical appliances in the car while waiting, it shouldn't be a big issue.
honeybee is online now   Reply With Quote
Old 17th August 2010, 06:20   #20
Googleman's Avatar
Thanked: 48 Times
Originally Posted by honeybee View Post
I had a Maruti 800 with Nippon central locking installed, and now have a Santro Xing with the Cobra central locking installed. Both systems are a little different, as in the Maruti, the driver side lock operates all the door locks, while in the Santro the driver side lock does not operate any other door locks..
That is what called central locking system. All 4 doors are operated through the driver's side. All autocops work the same way, they just lock the driver's side window, rest get locked automatically. If the driver's side lock does not control all other doors, the car does not have central locking system.
Your Santro is not equpped with Central locking? Strange
Googleman is offline   Reply With Quote
Old 19th August 2010, 09:36   #21
Originally Posted by CPH View Post
+1
This case un-avoidable. The doors will be unlocked 'only' if the key turned, no in case of engine-off by any other means.
Cars idling at crossings burn Rs 1,000cr a year in Delhi - Pollution - Environment - Home - The Times of India
The analysis say it saves lots of fuel, if it is more than 14 seconds in signal.
Old 19th August 2010, 10:37   #22
Googleman's Avatar
Thanked: 48 Times
Accidents only happen when the engine is turned ON I suppose.
Old 19th August 2010, 22:05   #23
Not quite completely true.
@GirishBhat, I suggest you explore everything else before going for a separate switch to kill the engine. I have gone through the situations you have described (as in travelling alone, with a laptop etc. but no untoward incident so far). As described earlier, in my M800 I used to switch off the engine (but leave the ignition on), and manually lock my door which would ensure all the doors remained locked. Soon it became a habit and other than the loud noise the locking/unlocking makes, it was smooth sailing.
Also whenever I travelled with my laptop, I either kept the bag in the boot (where it's almost completely secure), or if I had to keep it in the cabin, I placed it on the floor along the co-passenger seat. Shopping bags or other valuable articles I have shoved on the floor in the rear compartment too. That makes it nearly impossible for anyone to lift it easily, even if you were to get out of the car for some reason.
Old 20th August 2010, 06:06   #24
Googleman's Avatar
Thanked: 48 Times
Oh well you mean, the engine is OFF and handbrake in ON and the car goes and hits something and a nasty accident happens making the electrical fail?
Old 20th August 2010, 23:17   #25
@googleman,
I just meant that accidents can happen anytime to anyone, whether your engine is on or not.
Old 23rd August 2010, 11:24   #26
Googleman's Avatar
Thanked: 48 Times
@googleman,
That is correct. But chances are more when the car is in motion. So we should not opt to keep our doors locked always, specially when you are relying on an electrical or a motor.
Old 23rd August 2010, 17:06   #27
Thanked: 94 Times
Very sorry for the delayed reply. I have located my Nippon manual & here's the relevant info you need to turn off this feature.
JustCause is offline   Reply With Quote
Old 23rd August 2010, 18:01   #28
NFS-II's Avatar
Good luck
johnruben, I think the autocop guy meant to say this by using the word "configure in such a way".
These days most of the new cars come with a switch in the ignition keyhole which helps unlocking the car door as the key is removed. This is to prevent the nuisence of the door getting unlocked whenever engine is switched-off at signal stops.
NFS-II is offline   Reply With Quote
Old 25th August 2010, 16:37   #29
That is true.
I was trying to replay to bellow statement.
What I am trying to tell here is, In case of accident[while car engine is on] if the engine switches off or not [after the accident] the doors will remain closed. So people have to smash windows to open the doors. This is un-avoidable unless you have a mechanism to open the door locks in case of accident, but that is also dangerous.
Attachment 411828
Thanks a lot.
Old 26th August 2010, 11:26   #30
johnruben's Avatar
Thanked: 74 Times
Attachment 411828
Cool
Is it same for Autocop too ?
sounds like a DIY
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Engine switch-off procedure in cars rr_zen Technical Stuff 65 10th December 2009 21:55
Do you switch engine off soon after reaching destination? vnabhi Technical Stuff 15 18th January 2008 17:24
Do you switch your system off before shutting the engine down? kb100 In-Car Entertainment 29 17th June 2006 14:55
