Old 13th August 2010, 12:04   #1
Awaiting Email Confirmation
Default Need advice. Engine switch-off button.
I need to install a n engine switch-off button. I have the central locking in my car and every time when I switch-off the car in the signal it will un-lock all all the doors. It is really annoying. I'm planning to install a kind of switch-off button so that I can use it in signals.
Experts..Please advice.
Mods: I didn't get any similar thread. Please move it to appropriate thread.
Girish
girishbhat is offline   Reply With Quote
Old 13th August 2010, 12:10   #2
SS-Traveller's Avatar
Thanked: 11,626 Times
Why bother with an additional engine kill switch?
Get your central locking system rewired to unlock the doors when auxiliaries are switched off (i.e. when you pull out the ignition key). The system is currently wired with the "ignition on" circuit to lock/unlock doors - the circuit has to go through the auxiliaries wiring, so the doors will remain locked when ignition is switched off.
Which c/lock system is this, and what car?
Old 13th August 2010, 12:18   #3
@SS-Traveller:
Thanks for the quick replay.
I'm using Maruti Alto. It has the Maruti Nippon c/locking system.
Old 13th August 2010, 12:23   #4
Googleman's Avatar
Thanked: 48 Times
Originally Posted by girishbhat View Post
Girish
Girish
What you are trying is dangerous. The doors unlock after the ignition is switched off, and it is designed this way for a reason.
I suggest you to bear the annoying thing for your own good and safety.
It's kind of what you explained. The locking system is connected with the ignition and ofcourse runs on battery. There is a motor which is placed on one of the doors which is activated everytime the ignition is changed. This can be changed but is complex and unsafe.
Googleman is offline   Reply With Quote
Old 13th August 2010, 12:29   #5
This appears to be a dealer fitted system. Wrongly wired. Get someone competent to change around the connections to solve your problem. The doors should lock when you start the car and move off (increase in line voltage as the car revs), and should unlock when pulling the key out of the switch (and not when switching off the engine only).
You can get the details of how the system should work ideally, from the Nippon instruction manual too.
Old 13th August 2010, 12:34   #6
Googleman's Avatar
Thanked: 48 Times
I disagree. The door unlocks once you switch off the ignition, not after you pull out the keys. This is common between all auto lockers be it nippon or autocop.
Old 13th August 2010, 12:34   #7
vineetmanghani's Avatar
Thanked: 7 Times
This is how I've seen and experienced central locking systems work over 10 years and across 6 different cars from different manufacturers (Maruti, Honda, Toyota and Hyundai).
The doors lock after 5 or so seconds of turning the key to the "Ignition-On" position, irrespective of the car moving or not.
The doors unlock as soon as the engine is killed. Then one has to turn the key back to the "Ignition-On" position to re-lock the doors.
Couldn't have been wrong wiring on all the cars could it? I'm talking both aftermarket fitted systems as well as dealer fitted systems.
vineetmanghani is offline   Reply With Quote
Old 13th August 2010, 13:11   #8
johnruben's Avatar
Thanked: 74 Times
Girish
+1 same issue, but i wasnt bothered until i read this thread, however i wanted to stop the sensors very badly.
http://www.team-bhp.com/forum/techni...p-users-5.html (Some tips for autocop users)
So, I finally called autocop and they said will be coming to my place tomorrow to check wiring and fix the sensor sensitivity
johnruben is offline   Reply With Quote
Old 13th August 2010, 15:22   #9
rohan_iitr's Avatar
Thanked: 412 Times
What is it exactly that is bothering you ?
When stopping at a signal, when you switch off, doors are unlocked automatically. If you feel unsafe with the open doors, you could simply lock the driver side door manually. Since the car has central locking, all other doors would also get locked - problem solved.
Or turn the key back to ON position, the doors would lock after a few seconds (if it is so programmed in your security system). Security systems can be programmed to lock the doors after a delay of few seconds or after the car starts moving.
Rohan
rohan_iitr is offline   Reply With Quote
Old 13th August 2010, 15:53   #10
Every time I switch of the engine, it makes a "dhad" sound and un-locks all the doors, and locks it after few seconds with the same sound. And it is a security risk also. I have heard from the people who lost their mobile Phones in the signal while the windows were open. And what if someone opens the door and take out the bag with valuables like laptop? Y'll be in the signal and not be in a position to leave the car and chase them also.
In the traffic signal, it is a bit risky to keep the door open for few seconds also. Especially when you are alone with some valuables in the bag.
Old 13th August 2010, 16:41   #11
...complex and unsafe.
Why?
Not so. Check the Maruti OE factory fitted C/lock systems.
But not factory-fitted systems. Those open the doors only when the key is pulled out!
...it is a security risk also.
Totally agree with you. I had the same issue with my Accent (dealer-fitted Nippon system), solved as suggested earlier.
Old 13th August 2010, 16:47   #12
kri$hna's Avatar
Thanked: 29 Times
so, when you switch off the engine at a signal.. immediately switch the ignition ON, now your doors will lock up again & no one can open the doors, isnt it ?
I guess its not a huge problem to keep the ignition on for a few mins in a traffic signal. doesnt consume any fuel !
kri$hna is offline   Reply With Quote
Old 13th August 2010, 18:10   #13
If you switch on immediate also it will take few seconds [20 or so..] to lock all the doors.
http://www.team-bhp.com/forum/techni...ed-signal.html
http://timesofindia.indiatimes.com/a...ow/3335447.cms
My few cents towards pollution control..
Old 13th August 2010, 21:58   #14
Thanked: 94 Times
Cars idling at crossings burn Rs 1,000cr a year in Delhi - Pollution - Environment - Home - The Times of India
Please upload the pic of your NIPPON remote. This feature can be switched off for added security at secluded parking spots/ traffic signals. Try to locate a Valet switch (push button type, somewhere along the A-pillar). Your central locking system must have one. I have switched off the automatic unlock in my Alto as well.
JustCause is offline   Reply With Quote
Old 16th August 2010, 06:16   #15
Googleman's Avatar
Thanked: 48 Times
Why?
Well there are lots of answers for this. It is dangerous in case of an accident and the electricals fail.
Wonder why all 4 power windows is not suggested? Why would they design it the way it is? why wouldn't they manufacturers allow the doors to be locked throughtout? I suppose before bringing a product they do a lot of research and tests.
Anyways, there can be a long debate on this. I just gave an advice, it is up to people to take it or not.
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
Engine switch-off procedure in cars rr_zen Technical Stuff 65 10th December 2009 21:55
Do you switch engine off soon after reaching destination? vnabhi Technical Stuff 15 18th January 2008 17:24
Do you switch your system off before shutting the engine down? kb100 In-Car Entertainment 29 17th June 2006 14:55
