Old 18th August 2010, 09:55   #16
csateesh's Avatar
Thanked: 122 Times
Default Hyundai's feedback
Hello All
Bear with me if this OFF TOPIC but I did feel that this could be pertinent here.
I did write to cr@hmil.net on the concern of premature wear and tear due to BS - IV diesel.
After a few days (which they did highlight would be needed) they came back to me saying that they do confirm there would be no effects.
I did ask them the details about the tests that were conducted and the measured parameter.
They declined to share the same but re-iterated the fact stated above
Hope this helps
Sateesh
csateesh is offline   Reply With Quote
Old 18th August 2010, 10:07   #17
SS-Traveller's Avatar
Thanked: 11,630 Times
...they came back to me saying that they do confirm there would be no effects.
...details about the tests that were conducted and the measured parameter.
I would not have expected any different answer to that. Ask any auto manufacturer in India, and the answer would be just the same. The PR people answering your question wouldn't know what your (or my) concern is, and their answers are always stereotyped.
As Sutripta said, a technical specialist in Bosch/Delphi or in an oil co. should be able to answer this.
Old 18th August 2010, 10:19   #18
csateesh's Avatar
Thanked: 122 Times
I checked with the service centre folks Shom and they said the pump and injectors for Accent CRDi weren't from the above.
I wasn't sure whether to believe these guys are take it with a pinch of salt
I am trying to contact someone whom I know in HMIL to see if they can get some confirmation from the technical personnel
Sateesh
Old 18th August 2010, 10:41   #19
tsk1979's Avatar
Thanked: 16,422 Times
Originally Posted by sanagg1 View Post
I have some information from friends
The adulteration is done not only with K-Oil but also with spent lub.oils mixed with KO so the quality control may not be very easy for adulterated fuels.
But I am very sure it does not harm the engine by way of lubricity issue. However, choking your costly injector may be a more dangerous threat.
cheers
I am not too worried about adulterated fuel. Going by experiences of others, when fuel is heavily adulterated, the filters choke up. In the safari, there are series of filters, starting with a diesel water separater which are very very good. So any sign of trouble, these will choke up first.
Sateesh
I do not expect them to give you any hard data. Hopefully, Spike and BD can shed more light on this factor. After all they are the engine guys.
Old 18th August 2010, 11:05   #20
ph03n!x's Avatar
Thanked: 120 Times
Sateesh
The 3-cylinder 1.5 CRDi that Hyundai used in the Accent CRDi is from VM Motori.
ph03n!x is offline   Reply With Quote
Old 18th August 2010, 13:40   #21
Thanked: 245 Times
Okay, so it has 460 lubricity scratch diameter. I guess the lower number the better.
Now the oil company will meet this specification, but I am not sure whether after adulteration this parameter will be met.
BTW, what is the cold filter plugging point?
Its the cloud point for diesel: At what low temperatures does diesel crystalises into wax when flowing through a filter.
Why don't we get the oil companies, Bosch and Delphi answer our concerns.
Incidentally, lots of truck owners run their vehicles on Kerosene (and engine oil) mixture. When I had asked them about fuel pump life, they laughed and said that there is only a slight decrease, and from the economic PoV, they were faaaar ahead.
Cummins used to sell an additive to run their engines on SKO.
Sutripta
Oil companies will follow the specifications and automobile manufacturers focus on meeting the emission norms, I dont think any component in an engine is specific to BS3/4, its known worldwide what technology to use under what fuel to meet the norms. Other countries have gone through the same change without any challenges.
Old 18th August 2010, 13:54   #22
tsk1979's Avatar
but isn't 6 degree and 18 degree to high a temp. for example, I may go on a mountain trip during summers, and temperatures fall to 2-3 degree C!
Actually, independent studies took place in the US after many vehicles, esp older ones started reporting premature failures of critical components, esp high pressure fuel pumps.
At that time the scratch parameter was found to be 600+ instead of the required 500 or lower. California emission norms decree that ULSD has 10ppm sulfur. At 50ppm, we are 5x of what USA uses.
Old 18th August 2010, 14:15   #23
Thanked: 245 Times
Usuallly fuel specifications are set at levels that ensure most users will be free of wax problems(for this parameter), most of the time. Occasionally users will have problems in cold weather, but it is impractical to give complete protection to everyone and under all conditions.
IMO, we are the last of the countries to migrate and therefore, I hope we have taken all the learnings into account.
Old 18th August 2010, 20:15   #24
Thanked: 2,404 Times
A bit more than just meeting emission norms. Manufacturers have to give a warranty to the customer, and, I think, an undertaking to the government that the vehicle will continue to meet emission norms for xxx Km with nothing more than regular servicing.
However, we are not talking of new engines, but effect on older engines. Googling a bit shows that the major problem seems to be elastomer failure. The seal might cost Rs. 5, (and a new seal made of a polymer not affected by the new fuels might cost Rs. 10) but the effect of its failure would be rather more.
My Rs. 0.02
Sutripta
Old 23rd August 2010, 22:28   #25
joshguy's Avatar
Thanked: 92 Times
tsk1979 ,you made me think a lot!
btw will the bs4 fuels have that much impact on the fuel pump/injectors and performance of the car?
And to others who suggested 2s oil,dont you think the engine will emit more smoke due to this?
joshguy is offline   Reply With Quote
Old 24th August 2010, 10:13   #26
dkamath's Avatar
Thanked: 120 Times
Default Emission test readings
Guys, below might be off-topic, as am not well-versed with this topic, but my recent emission test seemed has got me thinking (of course, other than why was i lax at not renewing it on time, hehe).
Back to topic, the emission test done on 26th Dec,2009 reads K value of 0.15 and HSU as 6.25. The test performed recently, on 21st Aug, 2010, reads K as 0.27 and HSU as 10.96, nearly twice the previous reading. The engine and oil temperatures for the latest readings are a shade lower, but am not sure if they pose any bearing on the resulting values.
Additional info: The vehicle undergoes periodic service during May of every year. Considering the older reading taken 7 months after service, and the current one being 3 months after service, the expectation is the latest reading should've been lesser, or atleast on par with the older reading.
With the vehicle (a Tata Safari LX, BS-3), driver (that's me), fuel station (IOC outlet, Mysore Road, opp.BHEL industry, B'lore city), emission test centre (Balaji, opp.Rajajinagar RTO, B'lore) as well as the person who conducted the test too being the same, the only variable here is/was is the fuel, which was of BS-3 grade earlier, and is (hopefully) BS-4 now.
Any thoughts?
dkamath is offline   Reply With Quote
Old 24th August 2010, 11:58   #27
Thanked: 420 Times
@dkamath : Apart from fuel and oil temperature there is one more variable between the two readings and that is the RPM value.
In 1st test RPM is below 2900 most of the time and in 2nd test it is above 3100 most of the time.
IIRC in the last two emission tests at two different testing centers the guy asked me to increase RPM just to 2K RPM so don't know what should be the correct RPM to measure at.
BTW : Note the standard value and the wide margin between measured value does't the standard look too high for BS3 /BS4 ?
amitk26 is offline   Reply With Quote
Old 24th August 2010, 12:33   #28
Thanked: 245 Times
And your vehicle too has aged an year, more carbon in the system.
The real test would be to have 2 Safari's, BS3 and BS4 having run the same KM's and on their respective fuels.
Old 24th August 2010, 13:49   #29
dkamath's Avatar
Thanked: 120 Times
Thanks for the replies, guys! Just to add, and of course, presuming that the test system is the same everywhere in B'lore, the operator performing the test (he takes over the steering wheel while i watch with eyes open, hehe) holds a device with an LCD screen, instructing him to raise or lower the RPM. And it's got the instantaneous RPM readings being displayed too. Not sure why the RPM's taken for the tests are different this time. Anyways, since the readings are very well within the tolerable limits specified, am ok for now .
Old 15th October 2015, 13:39   #30
Thanked: 440 Times
Default Re: BS-4 fuel lubricity and effect on engine life
Is there any other 91+ RON fuel apart from Speed 97? "HP Power" and "Speed" are just normal Petrol with additives.
Is BS3 fuel lesser than 91 RON?
freedom is offline   Reply With Quote
Life's like that: Real life anecdotes. Sam Kapasi Shifting gears 534 15th February 2018 19:23
Apollo launches Amazer 4G Life - Claimed life of 100,000 kms Tushar Tyre & Alloy wheel Section 12 26th June 2016 18:39
Effect of Air Filter condition on Vehicle fuel economy. mclaren1885 Technical Stuff 19 25th April 2013 22:45
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
OOty effect..Victim of bad fuel.. Advice needed DRC Technical Stuff 7 9th October 2006 11:40
