Old 16th October 2015, 18:32   #31
alpha1's Avatar
Thanked: 958 Times
Default Re: BS-4 fuel lubricity and effect on engine life
Originally Posted by freedom View Post
Is there any other 91+ RON fuel apart from Speed 97? "HP Power" and "Speed" are just normal Petrol with additives.
Is BS3 fuel lesser than 91 RON?
BS2 was 88 RON
BS3 was 91 RON.
All the consequent BS (4/5/6) are 91 RON only.
Bharat Standards or Euro standard (or any other standardsinthe world) are about reducing the sulfur emission mainly. Hence each stage decreased the allowable sulfur content in the fuel.
Feeding an engine with higher octane number than the one that is required doesn't really affect (contrary to whatever placebo one experiences). The same goes for cetane number (applicable to high speed diesel)
I have no idea who all sell higher octane number petrol in India.
Old 16th October 2015, 20:25   #32
Thanked: 416 Times
Originally Posted by alpha1 View Post
BS2 was 88 RON
BS3 was 91 RON.
Polo TSI needs 91 as minimum RON and 95 is optimal. So in this case putting in 95 over 91 will definitely help.
freedom is online now   Reply With Quote
Old 19th October 2015, 14:42   #33
alpha1's Avatar
Thanked: 958 Times
Is this mentioned in the User manual?
What benefits are mentioned in the manual by filling RON 95 vs RON 91?
Old 19th October 2015, 14:46   #34
Thanked: 416 Times
It should be there in the manual, I will check.
But its clearly written on the fuel tank lid
http://www.team-bhp.com/forum/test-d...ml#post3823430
It says 91 is minimum and 95 as default.
Since it has high compression ratio, I would like to believe that at-least in this case, a 95 fuel would be better than 91. Especially for highway driving/twisties etc.
Old 19th October 2015, 16:53   #35
sgiitk's Avatar
Thanked: 3,752 Times
Ye, 95RON should be the Premium grade. May be ₹2-3 per litre costlier. let this be the premium rather than normal petrol with additives.
Old 1st February 2016, 20:03   #36
d3mon's Avatar
Thanked: 582 Times
As per the Shell page below, some of their outlets in Bangalore sell BS3 fuel, instead of BS4.
Now from the limited research I've done online, I've read that BS4 has a lower sulfur content, which leads to lower lubricity & lower fuel economy. And higher emissions, of course.
Should I stick to Shell BS3 (hopefully less adulterated than HP/IOC) or switch to HP/IOC?
Do all other petrol bunks dispense BS4 diesel? Are there other Shells which dispense BS4 diesel?
I have a Figo Aspire with the 1.5TDCi.
http://www.shell.in/products-service...ing-board.html
d3mon is offline   Reply With Quote
Old 2nd February 2016, 14:15   #37
prithm's Avatar
Thanked: 252 Times
IOC COCO outlets are shifting to BSIV. Check ones that are in heart of the city. Albeit they are releasing by April 1,2016.
prithm is offline   (1) Thanks Reply With Quote
Old 2nd February 2016, 15:07   #38
alpha1's Avatar
Thanked: 958 Times
I am sure they must be talking about Bangalore district.
They can't sell BS3 fuel in Bangalore. That would be illegal.
Old 2nd February 2016, 17:36   #39
mpksuhas's Avatar
Thanked: 3,270 Times
The difference is due to categorization of certain places as 'outside Bangalore'. For example, I guess Shell on Varathur road sells BS3, that is because Varathur officially comes outside Bangalore. Due to this BS4 rule is not applicable to bunks operating there.
d3mon: I am not sure which area you are located in Bangalore. However, you can check this link to get info about any other reliable bunks which sells BS4 fuel. Link (Trusted Petrol Pumps in Bangalore)
mpksuhas is offline   Reply With Quote
Old 3rd February 2016, 11:13   #40
prithm's Avatar
Thanked: 252 Times
Why is this illegal if I may ask ?
BS4 is still proposed to be launched by 1 April 2016 by IOC, are other players already way ahead ?
prithm is offline   Reply With Quote
Old 8th February 2016, 11:29   #41
alpha1's Avatar
Thanked: 958 Times
Bangalore (and about 10-15 other prominent cities) has been on BS4 since 2010!
It is illegal to sell BS3 fuel in Bangalore metropolitan city.
What you are reading of these days is the rest of India also moving to BS4 (which is on high sulfur BS3 since 2010).
Remember our country is being run by the inefficient (Govt) for the inefficient (PSU). This staggering was done to ensure that PSU refiners do not suddenly land up being unable to sell their ordure (high sulfur BS3 fuel).
Life's like that: Real life anecdotes. Sam Kapasi Shifting gears 533 8th December 2017 23:19
Apollo launches Amazer 4G Life - Claimed life of 100,000 kms Tushar Tyre & Alloy wheel Section 12 26th June 2016 18:39
Effect of Air Filter condition on Vehicle fuel economy. mclaren1885 Technical Stuff 19 25th April 2013 22:45
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
OOty effect..Victim of bad fuel.. Advice needed DRC Technical Stuff 7 9th October 2006 11:40
