Old 1st April 2016, 02:56   #151
Thanked: 13 Times
Default Re: How to Jump Start your car (dead battery)
The other day, when testing the headlights in the workshop, my Zen's battery drained off.
So, the mechanic took another battery and just held it in his hand upside down and touched the positive to my dead battery's positive terminal (I am not sure if he also touched the negative).
And then he asked someone to crank the engine - and voila - it started.
How safe is this method?
Replying to a very old post but felt it is very necessary to reply to this one:
This is a very very unsafe method. It could result in injury and immediately spoil the booster battery.
1) If any of the six caps are not tightened properly, acid could fall out on the hands / engine / the battery you are trying to boost.
2) Even if the caps are tightened, the acid would come down and almost half of the battery plates (which are originally immersed in electrolyte during a normal upright position) would be exposed to air. Drawing a vehicle starting current (50-100 ampere) from such air-exposed plates will cause sulphate to build up immediately and damage the battery.
3) It is never recommended to use the booster and dead battery connected terminal for terminal. The risk of electrical problems in such a case is high. This is the reason we connect the negative of the booster to the chassis of the car being boosted.
ankurbhageria is offline   (2) Thanks Reply With Quote
Old 1st April 2016, 09:35   #152
ankan.m.blr's Avatar
Thanked: 495 Times
Thanks. Some doubts
1. During boosting, both booster car & battery-dead car should have engine on with idling?
2. When the dead battery is able to be cranked, should we shut off engine of booster car?
3. In general what is the sequence of engine start & stop (both for dead-battery & booster car) during boosting and during disconnecting jumper cables.
ankan.m.blr is offline   Reply With Quote
Old 6th October 2016, 15:10   #153
smartcat's Avatar
Thanked: 12,284 Times
How to jump start a car with just a rope:
http://thegarage.jalopnik.com/how-to...ope-1787456976
smartcat is online now   Reply With Quote
Old 7th October 2016, 21:27   #154
Thanked: 2,130 Times
You'll most probably topple the car from the jack.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 24th July 2017, 11:32   #155
Thanked: 145 Times
The mechanic foolishly connected another battery in opposite terminals in my innova ( battery was from an indigo).
The indicators flashed for a second and he removed the battery.
Thereafter I pushed started the innova and drove home and parked it.
The ABS light is on.
Headlights, horns and indicators work, but power windows, music systems wipers don't.
I need a new battery for sure.
Has he blown some fuses or much larger damage is done?
vikramvicky1984 is offline   Reply With Quote
Old 24th July 2017, 11:49   #156
paragsachania's Avatar
Thanked: 10,912 Times
Originally Posted by vikramvicky1984 View Post
Check the primary fuses in the Engine compartment first. If he has indeed managed to connect another battery in opposite, high chances that the fuses would have blown and then check for respective fuses (for Power Windows, Head Unit etc) in the Fuse Box inside the cabin.
paragsachania is online now   (1) Thanks Reply With Quote
Old 24th July 2017, 12:13   #157
Thanked: 145 Times
Thanks a lot.
He indeed did that.
I am much worried about the ABS light.
Old 24th July 2017, 12:23   #158
NOTORIOUS's Avatar
Thanked: 87 Times
Any Reliable Places To Purchase Good Quality Jumper cables ?
looking for around 600Amp current rating.
NOTORIOUS is offline   Reply With Quote
Old 24th July 2017, 12:23   #159
Before anyone tries to clear that ABS light by disconnecting the battery (if that works), better to visit your ASC and get it scanned for the reason behind this ABS light.
Also, check the ABS Fuse too. It could be a possibility that this also has blown and hence the warning light.
Old 27th July 2017, 11:55   #160
Thanked: 145 Times
Mechanic is saying there is damage to alternator.
Will get to know exact details once its opened up.
Old 27th July 2017, 12:26   #161
R2D2's Avatar
Thanked: 1,224 Times
Mechanic is saying there is damage to alternator. Will get to know exact details once its opened up.
Don't blame the alternator right away. Generally connecting a battery without observing polarity can result in a blown main fuse among other things like damage to some electronic equipment and accessories.
This fuse is called the "Alt" fuse and is around 120A. It protects the circuit between the B+ (B=Battery) terminal of the alternator and the battery +ve terminal. Please ask him to check it.
It is located in the main fuse box under the bonnet/hood. Check the owners manual for details. Oh yes, removing this fuse is quite an exercise. It is a critical electrical part so please ensure you replace it with a genuine 120A (or whatever rating) fuse.
R2D2 is offline   (3) Thanks Reply With Quote
Old 27th July 2017, 12:30   #162
Aternator is the last thing I would suspect to have gone kaput here with what was reported earlier.
All fuses must be checked including that Heavy Duty Alternator one and only then an attempt must be made to check the functioning of the Alternator by ascertaining if battery is charging when the engine is running.
Trying to "repair" the charging system should happen next.
Old 27th July 2017, 13:24   #163
Thanked: 41 Times
To add.. check your connecting cables to the fuse box & the battery. Loose connection would give an impression of a failing alternator on engine startup, but the cable was the culprit in my case.
Adi22 is offline   (1) Thanks Reply With Quote
Old 27th July 2017, 13:35   #164
Thanked: 566 Times
The negative lead is connected to a bare metal grounding point/chassis to keep it as much away from the negative lead of the dead battery.
If the lead is directly connected to the negative terminal of the dead battery, there is a high risk of sparking which could potentially explosively ignite the Hydrogen gas accumulated in the dead battery causing serious injury.
Unfortunately, almost all the ready-made jumper cables marketed online and in local shops are made of thin copper (or whatever) wires surrounded by thick rubber insulation (to make the cables appear thick and heavy duty). They are no where close to supporting the Amperage rating needed to carry all that high current required for jumpstarts.
The best (and reliable) thing to do is purchase the heavy duty copper cables of the required length (like Finolex rated for 600 Amp) and buy the jumpers clips and join them to make the jumper cables. The longer the cable, the thicker the copper wire needed.
for_cars1 is offline   Reply With Quote
Old 29th July 2017, 10:51   #165
Thanked: 145 Times
Thanks a lot. You were correct.
Driver and mechanic had taken for a ride. Had claimed to replace alternator cutout n billed 3k. The abs light was fine but stereo and remote locking wasn't working.
I checked and found out they had put a wire to bypass tha fuse box and the 100a amp fuse was indeed blown.
After removing the wire, car is back to the same state as earlier.
Have parked it in closed garage. Will send it to asc when time permits.
Whole thing was my mistake, firstly don't trust a roadside mechanic to jumpstart ( which created the whole problem). Don't trust a new driver who we often felt pilferaged fuel.
Hadbadi mein bahut gadbadi ho gaya
vikramvicky1984 is offline   (2) Thanks Reply With Quote
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
DIY : Renew Your dead car / bike battery Hashim DIY - Do it yourself 40 20th May 2013 11:30
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Indigo --battery Light on when start and RPM meter is dead virender Technical Stuff 1 12th April 2009 14:10
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
