Old 29th July 2017, 11:06   #166
R2D2's Avatar
Thanked: 1,096 Times
Default Re: How to Jump Start your car (dead battery)
Originally Posted by vikramvicky1984 View Post
Thanks a lot. You were correct. Driver and mechanic had taken for a ride. Had claimed to replace alternator cutout n billed 3k.
There's no such thing as an alternator 'cut-out' or relay. The whole charging circuit is protected only by heavy duty fuses.
There is also an "Alt-S" fuse under the bonnet. Please check that too. The 'S' stands for 'sense". If this fuse has blown the alternator rotor field coils won't receive the excitation voltage when you turn on the ignition nor will it be able to 'sense' the battery voltage. Hence the name.
Have parked it in closed garage. Will send it to asc when time permits.
I'd recommend you disconnect the battery -ve (negative) cable if you intend parking the car over 10 days.
Whole thing was my mistake, firstly not trust a roadside mechanic to jumpstart ( which created the whole problem). Don't trust a new driver who we often felt pilferaged fuel. Hadbadi mein bahut gadbadi ho gaya
Road side mechanics follow the 'jugaad' system which means they just want to get the job done and the vehicle running. Safety does not figure in their calculations. The owners manual has clear instructions on how to jump start the vehicle. As an owner you should take the effort to become familiar with the process.
R2D2 is offline   (1) Thanks Reply With Quote
Old 29th July 2017, 11:24   #167
Thanked: 145 Times
Yes boss.
As I said I was in a hurry on Sunday to go somewhere with a large group in 3 cars. In a hurry to get the job done quickly we overlooked what the mechanic was doing. Few seconds of negligence on my part and the damage was done.
It was a Sunday so I couldn't attend the car and left it on the driver. Again negligence on my part.
I didn't even check or start the car until today. Again negligence
It had been raining non stop since Sunday and I was busy too- again an excuse on my part only.
A new battery amazon was added on Monday. I am sending it to asc through old driver who has maintained it the car since new. Should go in a day or two. I hope I will just have a to pay the money and everything will be alright.
Moral: if you don't have time, just park it aside and wait till you attend properly- use other car if you have else public transport. Shortcuts will make a simple push start and a new home delivered battery issue into many thousands and week.
This was the first time in 6 years car car went outside asc.
vikramvicky1984 is offline   Reply With Quote
Old 29th July 2017, 14:02   #168
Thanked: 995 Times
Originally Posted by for_cars1 View Post
Unfortunately, almost all the ready-made jumper cables marketed online and in local shops are made of thin copper (or whatever) wires surrounded by thick rubber insulation (to make the cables appear thick and heavy duty). They are no where close to supporting the Amperage rating needed to carry all that high current required for jumpstarts.
The best (and reliable) thing to do is purchase the heavy duty copper cables of the required length (like Finolex rated for 600 Amp) and buy the jumpers clips and join them to make the jumper cables. The longer the cable, the thicker the copper wire needed.
What I had done ages ago was
. Bought a long length of starter cable for Fiat 1100
. Searched for and bought large copper clamps from Junk shop
. Got the clamps soldered by Radiator repair guy
You can do the same, the only problem is finding heavy duty clamps. Most available are quite thin. Here a few that are sturdy
https://www.alibaba.com/product-deta...3.8.W2rOsn&s=p
https://www.amazon.com/Replacement-A.../dp/B01M7QRXAH
http://www.amazon.in/Generic-Insulat...inhydr18418-21
Aroy is offline   (2) Thanks Reply With Quote
Old 29th July 2017, 15:13   #169
Thanked: 220 Times
A few shops in JC Road, Bangalore are selling jumper cables for 1250/ 1550. Stuff is very heavy with large clips. Manufactured by Delhi based company. The shopkeepers do not know the Ampere rating.
Not sure if they are significantly better than the stuff available on Amazon for 350- 500 bucks. Any suggestions, or personal experiences to share?
ajayclicks is offline   Reply With Quote
Old 14th November 2017, 19:03   #170
Saanil's Avatar
Thanked: 186 Times
Got a very basic question for experts here. My A-Star's battery died recently and was jump started by a mechanic. Do I have to be worried that the life of the battery is over? This is surprising given then the battery is less than 2 years old. However, the battery is my father's Honda City also went dead in less than 2 years.
Should I consider replacing the battery? Is there a rule that if a battery dies once, it has just few months of life? Or jump starting a battery can ensure normal functioning of the battery?
Saanil is offline   Reply With Quote
Old 14th November 2017, 19:27   #171
R2D2's Avatar
Well, keeping a battery discharged will lead to sulphation and affect its life. So, the earlier you get the battery back to 100% charge the better it is. I assume the battery has been topped off with distilled water as and when required and your car's charging system is up to spec.
You do not need to replace the battery unless it is assessed to be faulty. They generally do a load and specific gravity test to determine this.
Since this is the 2nd battery that died in 2 years across 2 vehicles, need to ask if the running is low. If yes, consider buying a smart charger so you can charge/maintain the battery yourself. Believe me, it's cheaper to charge the battery using a bench charger than to use the car just to keep the battery charged.
A discharged battery doesn't hold up too well in the long term. But don't fret and replace it just yet. Just have the battery fully charged and assess its performance over the next few months to determine if a new one is required.
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
DIY : Renew Your dead car / bike battery Hashim DIY - Do it yourself 40 20th May 2013 11:30
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Indigo --battery Light on when start and RPM meter is dead virender Technical Stuff 1 12th April 2009 14:10
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
