Old 16th December 2008, 18:37   #46
Thanked: 120 Times
Why the confusion with postive and negative terminals? Wouldn't connecting +ve to +ve & -ve to -ve work? Anything wrong with that?
HappyWheels is offline   Reply With Quote
Old 16th December 2008, 18:45   #47
vikram_d's Avatar
Thanked: 928 Times
Neve connect -ve to -ve. It always has to be -ve of booster car to engine ground (even body ground works in most cases). Hydrogen gas is present inside the battery and is extremely flammable. Slightest spark and you will have an exploding car.
Old 16th December 2008, 18:52   #48
Thanked: 142 Times
Any advise on making jump start cables? I know that any auto electric shop would be able to solder (not the normal solder used in electronics - proper melting of zinc / lead is required) on clamps onto thick wires.
I also suggest that anybody with a car with a battery more than 24 months old should spend 100 bucks to buy a digital multimeter. It should tell you the voltage fo the battery.
Can gurus please post the acceptable voltage limits? (I can post the current voltage on my car; but its battery is healthy).
Old 16th December 2008, 19:09   #49
vikram_d's Avatar
Thanked: 928 Times
For making jumper cables just buy good quality electrical wire. 4 gauge or even 8 gauge is enough. Most petrol cars require minimum 11.5 volts to start. This is without any other load on the battery.
The biggest issue with dead/dying batteries is that if you run the car for about 15 mins and check voltage they will show proper readings. But the thing is that they will not hold that charge for very long. They drain out quicker.
I recently changed my battery. The only thing that told me the battery was weak was that it's voltage would be 11.4 - 11.7 volts in the mornings. The new battery reads 12.3 to 12.5 volts in the mornings. When I went to got the battery replaced I found out that 2 cells of the old battery had completely gone bad. There was brown coloured residue in the electrolyte of those cells. The only things that kept that battery going was my 60 kms daily run to and from office.
Old 17th December 2008, 20:16   #50
Default Car starting up now
Surprise! I cranked up today and my car is starting now. Now the guy from Amaron came and he checked and he showed in his multimeter that battery is weak. Normally it is showing 11.9 to 12.x but while cranking up it is showing 8.x to 9.x . Now i am confused whether to change the battery or not.
I need your advice guys.
vennarbank is offline   Reply With Quote
Old 17th December 2008, 23:12   #51
jat
It is normal for a battery voltage to dros to so low during cranking (depends on Ah of battery). However, how many starts you can get and does the voltage returns to normal after the cranking with engine stop and lights etc on. If not the battery has run down and needs replacement. The best way is to carry out a load test but some workshop. There you can see how much the voltage drops and how fast the battery is discharged with a nominal charge of about Rs 30~50/- or even less.
jat is offline   Reply With Quote
Old 17th December 2008, 23:59   #52
Hashim's Avatar
Thanked: 32 Times
If the battery voltage dips below 10v on normal load then battery is definately weak and no more good for use in car. You should change the battery.
Hashim is offline   Reply With Quote
Old 18th December 2008, 01:26   #53
aah78's Avatar
Thanked: 1,428 Times
Arrow
Modern cars should have dedicated +ve and grounding (-ve) points marked on the body - check user manual.
If you can't find a point, cover-up the battery terminals with some electric-tape (even your regular cello/scotch tape will do), just to prevent any unwanted occurrence (boom!).
If you're battery's 3 years or older, then yes, change it. If it's new and you don't use your car too much, then shop around for the funky trickle charger mentioned earlier.
aah78 is offline   Reply With Quote
Old 22nd December 2008, 16:24   #54
Default Some people never learn quickly and that is me
Now i have changed the battery to Amaron Black. Amaron GO /FLO was my choice but not available under the circumstances given below.
Saturday, 20th, decided to take car for change of battery. Called the guy and he told me to come late afternoon since he is stuck up somewhere else. I told him that i need to take car to Vandalur zoo. He told that should not be an issue since car is self starting. I took his word for granted and went to the zoo since my son was pestering me for more than a week. Just i entered the zoo and trying to park a car suddenly reversed. so i braked suddenly and the car stopped. And it did not start at all.
My wife gave a i told you so look. I asked my wife, kid and in-laws to go ahead into the zoo and book for lion safari. Then i asked for battery shop. The people pointed me to a shop which had only exide batteries. I told him i need Amaron. He called someother shop and told me that they have only battery with 18 month guarantee only. I did not have option since even if i call Amaron helpline it will take more time to come. So i told this guy to go-ahead and in the meantime went to IOB ATM and got the money.
Now with battery in a cycle the shop owner came with me and changed the battery. The rate is Rs.2156 and for old battery the exchange price is Rs.200.
Once everything done and warranty card got i was happy that it was over quickly [less than an hour]
And ofcourse i did saw the lion safari
And thanks to our team-bhp for guiding me choosing the battery.
Old 28th December 2008, 14:23   #55
My car (Wagon R) is 4.5 years old & done about 40K Km. I have not had issues with starting the engine though it takes slightly more cranking than what I am used to. Recently i noticed that while driving my car horn reduces in volume after I use it a couple of times (starts sounding as if it has a sore throat :-) ). As I drive, if I do not use the horn for more than 15 min it comes up fine but then drops in volume once again. I am not sure whether this is a battery problem. Headlights, stereo, Ac, Wipers all seem to be working fine. The dashboard battery indicator comes on before I crank and it switches off after I start the engine as usual. Doesnt this indicator indicate when the battery needs to be replaced? Do I need a new battery - any shop in Bangalore & brand that someone can suggest?
Rajesh
hsejars is offline   Reply With Quote
Old 28th December 2008, 14:44   #56
Thanked: 142 Times
4.5 years is 1.5 times the expected life of a battery. More than 3 years and you will be better off replacing it - but first, take advice of a nearby battery shop.
Old 28th December 2008, 15:02   #57
aseem's Avatar
Thanked: 414 Times
The reason jumper cables are not popular in India is twofold:
a) It doesnt snow here in most parts of India. So cold battery that wont start is not an issue
b) We have manual transmission cars mostly, that can be dhakka started. Try doing that with an automatic....
aseem is offline   Reply With Quote
Old 28th December 2008, 15:23   #58
gigy's Avatar
Thanked: 40 Times
The point is to connect the negative from booster car to a place on the dead car which is sufficiently far from the dead battery. this prevents any gas buildup from igniting from the small spark produced during connection.
Old 28th December 2008, 17:23   #59
anjan_c2007's Avatar
Thanked: 4,196 Times
This is the one year old battery of my 1955 Landmaster which is used every weekend.Why do the sea blue salts start forming near the terminals? This salt is deadly and spoils the paintwork of the car causing corrosion in its metal body. It is soluble in water.
anjan_c2007 is offline   Reply With Quote
Old 28th December 2008, 20:41   #60
Thanked: 243 Times
Anjan, that is 'normal' corrosion that takes place on battery terminals. Usually lead sulphate and maybe some copper sulphate.
Can be washed off with warm water and an old toothbrush. Wash off the salts with copious amounts of water.
Then apply petroleum jelly or white Vaseline liberally to the terminals and connectors. This prevents the salts from forming.
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
DIY : Renew Your dead car / bike battery Hashim DIY - Do it yourself 40 20th May 2013 11:30
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Indigo --battery Light on when start and RPM meter is dead virender Technical Stuff 1 12th April 2009 14:10
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
