Old 17th August 2010, 13:49   #1
panky12345's Avatar
Thanked: 149 Times
Default Weird starting trouble with Indigo
hi guys,
experienced a strange thing this morning.. when tried to start my Indigo, there was a sudden noise like rapid "kad-kad-kad", with the dashboard indicator lights (hand brake, oil etc) blinking continously. the ODO was also blinking, then it settled. (this was when the ignition was in "ON" position.) the car refused to start when cranked.
checked the volts on the battery using a DMM.. showed 10.60V
any ideas what could be wrong?
here's a brief video..
Old 17th August 2010, 14:25   #2
tsk1979's Avatar
Thanked: 16,421 Times
Your battery has gone down.
Try jump starting with a fresh charged battery.
After that check voltage. If you are getting 13.5 etc., your alternator is okay.
This means the cells in your battery are gone.
How old is the battery?
Old 17th August 2010, 15:01   #3
panky12345's Avatar
Thanked: 149 Times
thanks tanveer.. strange indeed! car was perfect till last night, and am sure there was no lights etc that remained on.
battery is OEM app 2.5 yr old exide.
Old 18th August 2010, 14:50   #4
panky12345's Avatar
Thanked: 149 Times
you were right tanveer.. replaced the battery with amaron, everything seems to be settled now.
Old 18th August 2010, 15:16   #5
tsk1979's Avatar
Sometimes, a faulty alternator can lead to premature battery failure(15V+spikes). So do attach the DMM, and see voltage, first without any lights, AC etc., and then switch on the headlights, the AC at full blast without switching on the compressor, fog lamps(if any).
Then switch on the AC compressor also.
Old 18th August 2010, 17:56   #6
panky12345's Avatar
Thanked: 149 Times
I connected the DMM, abeit without switching on the lights etc. It was 14.48 after acclerating and 13.68 - 13.78 idle.
Old 18th August 2010, 18:04   #7
tsk1979's Avatar
Thats perfect. Alternator is good, problem should go away now.
Old 18th August 2010, 23:39   #8
greenhorn's Avatar
Thanked: 1,516 Times
its times like this you wish you had an analog multimeter
greenhorn is online now   Reply With Quote
Weird noise from dashboard when starting the car RocketRaccoon Technical Stuff 6 8th December 2015 14:08
Karizma ZMR: weird starting problem farhadtarapore Motorbikes 18 15th February 2013 15:02
Starting trouble Fiero F2? ramki067 Motorbikes 0 23rd April 2007 12:10
Starting trouble and Musical Car COUGAR Technical Stuff 3 4th January 2007 05:48
Dark liquid dripping ... from exhaust and starting trouble .. new ZEN gchandra Technical Stuff 3 21st October 2005 09:17
