Old 28th August 2010, 04:45   #31
di1in's Avatar
Thanked: 92 Times
The above discussions, leads me to strongly suspect your speedo. and just like Shan2nu suggested, get it fixed outside A.S.S for cheap, or you could go to A.S.S and change the unit. But replacing the unit may reset your odo.
Yea, guess i'll get someone to check it out.
Originally Posted by Shan2nu View Post
Yup, it read 70kmph@2000rpm in 5th. ECU still reads 70kmph, but the speedo shows 74kmph.
Even the calculated speed wrt engine speed, wheel size and gearing is 70kmph.
engine speed / gear ratio / final drive ratio x wheel circumference (inches) x 2.54 / 100000 x 60 = vehicle speed (kmph)
2000 / 0.774 / 4.058 x 72.8 x 2.54 / 100000 x 60 = 70.64kmph
Shan2nu
Thanks man, I need to check the speedo for those variations though.
di1in is offline   Reply With Quote
Old 29th August 2010, 21:02   #32
EFF-EIGHT-BEE's Avatar
Thanked: 98 Times
I think there is a problem with FFE installation, the top end power band of the engine is being affected by the set up going by your description.
EFF-EIGHT-BEE is offline   Reply With Quote
Old 30th August 2010, 22:31   #33
di1in's Avatar
Thanked: 92 Times
What? I don't know understand..
My new Gypsy so many questions - Changing the gear ratios mrgizzer Modifications & Accessories 6 28th August 2012 12:51
Guide on gear ratios vikid 4x4 Technical 14 6th May 2010 15:41
About Gear Ratios & their Relation to Tyre OD, Torque, Speed etc speedsatya Technical Stuff 90 8th April 2008 11:50
help reg gear ratios freakr Technical Stuff 18 19th April 2005 03:10
What are gear ratios? sridhar24 Technical Stuff 8 1st March 2005 20:38
