Old 25th December 2014, 23:29   #136
Default Re: Tata Manza - List Of Problems
Originally Posted by anilp View Post
Exactly, Amit. As far as I'm aware, modern diesels don't use glow plugs much unless the temperature drops. And my running is in tropical Bombay where the temperature is mostly in 30s. My car is stock, with no electrical changes whatsoever.
Anil, so what was the diagnosis finally? I came across a similar case at TASS in gurgaon and the problem was with the ditributor wire line. make sure you get it checked at a different TASS (just to make sure you got it identified correctly).
vanatlarj is offline   Reply With Quote
Old 26th December 2014, 09:01   #137
Thanked: 195 Times
Since the diagnosis was not changing, I escalated the issue. After much back and forth, and the fact that this happened immediately after the car was just serviced, they charged for only one glow plug. Thanks a lot for this tip. I'll get the distributor line checked now.
anilp is offline   Reply With Quote
Old 22nd August 2015, 13:21   #138
Thanked: 12 Times
Default Engine temperature guage reading with/without ac
I've the following problem (?). Should I be worried?
The car: Manza elan 2012, 32k on the odo.
The problem: the temperature guage reading is more than usual. Also, there is variation in readings with ac & without ac. The reading without ac is higher.
When the problem started: I noticed the higher levels in engine temperature reading, a couple of days before. I took the car home, did a check of blower & other fuses (I'm no expert I used the picture on the fuse box). Nothing seemed to be wrong. After half hour I came back, with the idea of starting the car and listening if the blower cuts in. The car however did not start. I called the emergency assistance number. A technician came within half hour. He brought with him a battery, and using it started the car. After further checks, running the car engine in neutral to reproduce the complaint(problem was repeated), he declared that every thing is fine. I changed the battery on his advice. My concern on the temperature guage remained. When I started driving again, I find the guage reading going above the usual mark. Please see the picture.
Now should I be worried?
lsjey is offline   Reply With Quote
Old 22nd August 2015, 13:36   #139
dhanushs's Avatar
Thanked: 4,119 Times
^^ Hi, If the temperature remains at where you've shown in the picture, it's ok. However, if it goes above that half line mark, it's cause of concern.
Old 22nd August 2015, 14:04   #140
Thanked: 12 Times
Thanks dhanushs. I feel better now. What I don't get is why this sudden change in the readings?
Old 22nd August 2015, 22:18   #141
parth.jain's Avatar
Thanked: 100 Times
Did the temperature gauge always go to this mark after driving for sometime. I feel otherwise. It's a lil wee bit more than it should go normally.
How much did you drive when the temperature gauge reaches till 'escalated' level?
parth.jain is offline   Reply With Quote
Old 23rd August 2015, 21:42   #142
Thanked: 12 Times
Well the temperature guage never used to go above the one third mark. In this case (when I took the picture),I'd driven about 20kms in the city traffic about one hour.
Old 23rd August 2015, 23:48   #143
Tanmay K's Avatar
Thanked: 170 Times
It does seem higher than what I usually see on my Manza. I'm on petrol, however, and that might make a world of difference.
You've probably checked your coolant level and the radiator fan? They might be ok since your 30k service probably wasn't done too long ago.
Another point you should observe is if the temperature goes down a little when you drive sedately on highways (if not, it could indicate coolant flow issues). Heating in the city usually implies airflow issues.
The fact that you get different readings for AC on and off likely rules out a faulty sensor (although your observation was admittedly counterintuitive).
Tanmay K is offline   (1) Thanks Reply With Quote
Old 23rd August 2015, 23:53   #144
mahesh_sn's Avatar
Thanked: 147 Times
Nothing to worry I guess. In my car, the needle shoots up to the middle mark within few km and stays there. I don't exactly remember when did it start but it has been happening for quite sometime now.
mahesh_sn is online now   Reply With Quote
Old 24th August 2015, 17:56   #145
Thanked: 12 Times
By middle you mean the second mark? I see markings for one third, two thirds and high.
Old 24th August 2015, 18:02   #146
Thanked: 12 Times
Originally Posted by Tanmay K View Post
I
The temperature does go down when the car is moving for some time at speeds above 20kmph approx for some time. If the car been moving at 40kmph approx for about 5-10 mins the temperature drops to one thirds on the guage. Should I do a radiator flush?
Old 24th August 2015, 22:35   #147
Tanmay K's Avatar
Thanked: 170 Times
I was tempted to suggest this earlier. Whether that would help depends on if you have reason to suspect that the coolant/water ratio was mixed incorrectly at the time of last flush/top-up. Hopefully the radiator isn't partially clogged.
It seems you may not have a pressing need to address the issue immediately if the needle doesn't go beyond half-way mark, but out of curiosity for further deduction you could try and see if a flush helps.
Old 26th August 2015, 00:06   #148
mahesh_sn's Avatar
Thanked: 147 Times
Sorry, my bad. Yes, the second mark is what I am referring to.
Old 1st September 2015, 14:36   #149
Tanmay K's Avatar
Thanked: 170 Times
The DIS on my Dec 2010 Manza Aura decided to die yesterday. TASS SA quoted me a full assembly replacement for 13k (without bothering to take a look in detail). Here's a picture of how it looks like with and without flash:
Any ideas as to what's wrong with it and any way the display can be salvaged without spending 13k?
Tanmay K is offline   Reply With Quote
Old 1st September 2015, 16:33   #150
audioholic's Avatar
Thanked: 5,268 Times
Attachment 1409481
So from what I see the display has gone dim? If thats the case then try taking it out and showing it to an electronic repair shop. Maybe they can fix a small component or two and get it back to shape. I dont think anything major has conked out. So do give it a try before spending those 13 grand.
audioholic is offline   Reply With Quote
Tata Indica - List of problems Ferrari1976 Technical Stuff 1202 25th June 2017 01:46
A story of 3 workhorses: 2 Santro's and a Manza, Edit: Santro sold, Manza at 100k+ amit1234singla Long-Term Ownership Reviews 115 10th August 2014 21:53
Tata Manza - Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:58
Tata Manza Aura+ 6k kms done - slowly emerging problems 5kmiles Test-Drives & Initial Ownership Reports 29 25th September 2010 18:41
