Old 30th August 2010, 16:26   #1
Thanked: 48 Times
Default RPM going wild at start on idling in Matiz
There is a strange problem in our matiz, which is around 10 years old. The RPM will increase without any throttle input and it will keep on varying from low to high. Once you put on the first gear and push off it will go back to normal but on idling the engine will sound like some one is revving it again and again. Any idea what could be the source of this problem. One mechanic suggested that one valve is bad. Could it be the issue?
rock75 is offline   Reply With Quote
Old 30th August 2010, 17:31   #2
pranavt's Avatar
Thanked: 274 Times
Idler valve is probably choked up. Get it cleaned, no need to buy a new one. If that doesn't fix it, check for vacuum leaks.
Old 17th November 2010, 22:43   #3
locomotor's Avatar
Has the problem been resolved??
locomotor is offline   Reply With Quote
Old 20th November 2010, 21:03   #4
Thanked: 28 Times
There was a similar problem in my friends esteem the idling rpm varied between 900-1200 rpm on starting. A scanner was connected to findout. the sensors were ok.
Check the resistance of the plug wires and there is an optical sensor in the distributor. Pls check that.
kavesh55 is offline   Reply With Quote
Fiesta engine jerks and rpm varies while idling tortoise Technical Stuff 45 19th May 2017 21:46
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
5000kms and 12 Passes, a 20 day wild wild ride to the roof of the world! tsk1979 Travelogues 556 19th August 2015 10:42
A Wild Wild ride to the Mighty Chansal Ghati tsk1979 Travelogues 44 26th January 2009 18:21
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
