Old 19th September 2010, 02:22   #16
pranavt's Avatar
Thanked: 274 Times
It does not look like a coffin. Google Warner R4, yours looks eerily similar to that.
Old 19th September 2010, 10:17   #17
Hashim's Avatar
Thanked: 32 Times
Nice job! keep it up man.. only book knowledge is not enough and since you are doing lots of practical work like this one, you will become one great engineer.
Install some lights in front and brake lights in rear. One easiest work and will make your ride look even good.
Hashim is offline   Reply With Quote
Old 19th September 2010, 11:09   #18
valhallen.282's Avatar
Thanked: 164 Times
First kudos to the effort!
Second yes the kine does have a transmission v-matic. its a belt drive with auto clutch. That massive black section at the end. (You'd already know that) the clutch sits at the wheel end of the housing along with a 3 gear assembly (I know this coz I shattered a few teeth on my kine's gearbox. IF you manage to install this assembly you will also get a central rear brake that sits in the same housing. Though I don't know how you will adapt the whole assembly!
EDIT: ok I just managed to see your pictures clearly! issues of mobile view. Can you post a picture of the other side of the transmission housing which you have adapted for the chain sprocket. (I'm not even sure I have the technical words right!)
valhallen.282 is offline   Reply With Quote
Old 20th September 2010, 16:07   #19
karthik123's Avatar
Thanked: 35 Times
Otherside of transmission housing? don't know what you mean dude but i think you meant the live axle? here's a picture of it.
We put a sprocket to the crank and live axle and the ratio is around 1:4.
karthik123 is offline   Reply With Quote
Old 20th September 2010, 16:09   #20
karthik123's Avatar
Thanked: 35 Times
Haha, only need to get the bulbs, will try to install after all the other work is done.
Old 20th September 2010, 17:33   #21
msaudf's Avatar
Thanked: 152 Times
bike/scooter suspensions are best for your kind of vehicle, good choice. but please remember to add a control arm/balance rod to your suspension. i think balance rod is better and cost efficient.
the kinetic uses a CVT (continuously variable transmission) so i guess your setup is fine,
Continuously variable transmission - Wikipedia, the free encyclopedia read about the tranny here.
disc brakes as you mentioned are expensive, but you can always buy used ones and another huge advantage here is the better stopping power and that you'll only need one for each axle, that eliminates tweaking of each wheel cylinder/adjuster for a stable stop. i guess start by just having the rear brake and only if you find it necessary add the front one.
anyway keep up the good work. now am gonna be hooked to your thread.
cheers buddy
Saud
msaudf is offline   Reply With Quote
Old 20th September 2010, 18:04   #22
arcotsrinivas's Avatar
Post deleted by the Team-BHP Support : One-liners that add ZERO value to the thread are strictly prohibited on Team-BHP. In fact, they are considered as SPAM. Please do not hit the post submit button unless you have something of value to add to the thread.
We advise you to visit our board rules before proceeding any further.
arcotsrinivas is offline   Reply With Quote Received Infraction
Old 21st September 2010, 11:49   #23
Thanked: 164 Times
yep in here is your transmission with auto clutch and you will find that holding the engine at lower revs say 20 kph on your build (its below 30 on the bike) for extended periods you tend to lose some of the initial bite. thats your clutch wearing out.
the wheel housing (the bit you replaced with a sprocket) on the live axle was the rear brake.
and about the engine yeahhhh its a buzzy little thing. thats why i still have my bike with me
i have a (rather dumb) suggestion and you will find this exceedingly amusing if not hilarious.
try nfs underground 2 it gives you complete adjustability of suspension and helped me understand a lot about exactly what does what!
Old 21st September 2010, 12:10   #24
Cartman's Avatar
Thanked: 225 Times
Wow! Nice machine you got there. You know, I'm an year younger than you, I'd probably do the same when I get into engineering. These are things you remember throughout your life. The hard work, the last minute adjustments et all.
All the best!
PS: Attaching pics of the Warner R4.
Cartman is offline   Reply With Quote
Old 21st September 2010, 15:26   #25
bhp_maniac's Avatar
Thanked: 111 Times
Thumbs up
Oh man, what a great thread am I following. Awesome work bro. Well done, and keep coming. With the kind of ideas we T-BHPians got, am sure your ride will become better and better along with the thread getting aged.
bhp_maniac is online now   Reply With Quote
Old 22nd September 2010, 14:44   #26
karthik123's Avatar
Thanked: 35 Times
So i guess the clutch is worn out, will figure out how to replace it, is it like a centrifugal clutch? thanks man was not able to diagnose the problem, I was thinking we got the sprocket ratios wrong and stuff. Yeah, i played nfs underground 2, what a game it was! will try to play it again this time only concentrating on turning part
All the best!
Thanks, all the best for your project man! thanks for posting the pics of warner r4, wicked machine.
Thanks, the ideas in this thread are sure inspiring, we're thinking of making something like this with a bigger engine and tubular chassis, something on the lines of warner r4 or ariel atom ( atleast in looks ).
I will try to fix the clutch and do the suspensions before 30th sept, will post the pics after that.
Old 22nd September 2010, 15:14   #27
Thanked: 164 Times
es I think it is. It has three clutch pads with release springs and washers. Please note to remove the cover housing of the clutch you need a special wrench. You can't just open out the housing. (hint: its inside the black enclosure)
Another hint: KICKIN GAME! Try and play with cars that drive like go carts like the rx 7 and the miata. (Rwds)
Also look at videos of the ariel atom. Its a honda civic engine supercharged.
I just saw the pics again I see that you've got the front end comletely welded. How you gonna install the sus?
Old 22nd September 2010, 15:35   #28
srishiva's Avatar
Thanked: 929 Times
Very good start. Hope you will build all other pieces into your structure. You can keep upgrading the parts (drivetrain, suspension) which will help in learning.
srishiva is offline   Reply With Quote
Old 22nd September 2010, 16:53   #29
karthik123's Avatar
Thanked: 35 Times
I'm going to cut near the spindles in the front to install the suspension.
I'll ask a mechanic to help out opening to clutch housing. Do you have any idea about the computer programme "Blender", not able to see measurements from the .blend files, which 3d model plans, need to learn how to use this.
Thanks man.
Old 25th September 2010, 08:38   #30
Thanked: 164 Times
Nope sorry no idea about the program. Did you manage to get the clutch and gears checked out yet?
Check this mercedes 2008 sls out _Crazi4Speed_ The International Automotive Scene 8 6th October 2004 01:36
check out this 850 bhp monster - Lotec Sirius salil_kulkarni The International Automotive Scene 5 13th August 2004 00:33
check out this bmw 328ci manticore The International Automotive Scene 8 24th May 2004 23:32
All new M6, X7, M3, M4 & few others, check it out _Crazi4Speed_ The International Automotive Scene 7 10th May 2004 21:44
Check check... vrrroooom Revvmaster Shifting gears 5 10th April 2004 13:30
