Old 25th September 2010, 23:49   #31
Thanked: 660 Times
congratulations!
that must have taken lot of efforts. Keep up the good work.
Old 24th October 2010, 11:03   #32
karthik123's Avatar
Thanked: 35 Times
Default Update on suspension process
Hi guys,
Got busy but still managed to do some work on the cart, installed bike suspension on the back and put up brakes on both the tyres ( Disc brake plan didn't work out because disc brake is very expensive . )
There's a problem with the clutch of kinetic but other than that nothings wrong and "all iz well"
Things to do next :
Secure the seat in its position, use more rubber and reduce vibrations, get a plan to install the front suspension
Ps: not able to post pictures as the pics are 1.3 mb , 300kb more than allowed limit which i didn't know off, will resize and post later
karthik123 is offline   Reply With Quote
Old 24th October 2010, 11:31   #33
Thanked: 3,768 Times
Hi Karthik,
Congratulations.
I am sure the final outcome would be awesome.
Keep the pics coming.
SILVERWOOD is offline   Reply With Quote
Old 24th October 2010, 20:56   #34
karthik123's Avatar
Thanked: 35 Times
Default Here are the pics
Installed the rear suspension, theres play and it works fine
Old 29th October 2010, 19:51   #35
@karthik123, Wow it has been executed so well. The weld job looks very professional! How about reducing the length, attaching a mower in the front and marketing as a ride-on land mower ?
mod-the-pc is offline   Reply With Quote
Old 29th October 2010, 23:57   #36
Thanked: 64 Times
Congrats on the commendable feat. Do think of a different name though.
The nomenclature reminds me of a conversation from the movie 'Iron Man'.
Jayabusa is offline   Reply With Quote
Old 25th November 2010, 20:51   #37
karthik123's Avatar
Thanked: 35 Times
finished with all the stuff , here's the final result
got a tractor like screw suspension in the front, only problems left now is the chain keeps falling off as it doesn't sit on the sprocket properly, will replace it soon. Got a new paint job too
Old 25th November 2010, 21:12   #38
superb effort there Karthik!!it looks simple and effective.
chain falling off could it be because of the suspension mount between the engine and chassis (in the above pic?)
get a spring tensioner (the ones seen on geared cycles) that might work.
i have one word for the execution 'neat'
EDIT: i realise it now after staring at the pic it doesn't affect it. sorry. still tensioner might work
somspaple is offline   Reply With Quote
Check this mercedes 2008 sls out _Crazi4Speed_ The International Automotive Scene 8 6th October 2004 01:36
check out this 850 bhp monster - Lotec Sirius salil_kulkarni The International Automotive Scene 5 13th August 2004 00:33
check out this bmw 328ci manticore The International Automotive Scene 8 24th May 2004 23:32
All new M6, X7, M3, M4 & few others, check it out _Crazi4Speed_ The International Automotive Scene 7 10th May 2004 21:44
Check check... vrrroooom Revvmaster Shifting gears 5 10th April 2004 13:30
