Old 1st September 2010, 21:55   #1
anilisanil's Avatar
Thanked: 288 Times
Default Figo's screeching sound (and some other problems) solved!
Today I have been to Ford service center and was going around the garage as my car was serviced.
Then I found out a TSB (technical service bulletin) in their notice board:
It has detailed explanation on how to solve:
  1. screeching sound from rear left
  2. windows rolling down problem
  3. horn problem
Apparently the screeching sound is due to some plastic/metallic clips on the roof. These are to be cut to allow the plastic locks to lock properly. There is proper diagram on how to solve the issue too, I have asked the SA to send me the mail of all three issues for which he agreed, will post them here once i Recieve them!
SO Figo owners rush to your ford dealer if you still have above listed problems!!
Mods: kindly merge if a similar thread exists!!
anilisanil is offline   Reply With Quote
Old 1st September 2010, 23:42   #2
Thanked: 658 Times
So they admit they have these problem on newly launched Figo.
Old 2nd September 2010, 03:05   #3
anilisanil's Avatar
Thanked: 288 Times
So sweet, no? In fact they have put this on the notice board also. Good to see that they are willing to solve the problem.
And not all the cars have the above problem, I think it is a few earlier batches I guess!
Old 3rd September 2010, 15:51   #4
Brix's Avatar
Thanked: 23 Times
Good initiative.
Although, I dont have the above problems mentioned.
Brix is offline   Reply With Quote
Old 3rd September 2010, 18:35   #5
anilisanil's Avatar
Thanked: 288 Times
Neither do I!
I had a few screeching noises but they are due to an accident my car met with!
While it is sad that this missed the quality control (apparently some problem with fitting the metal locks into the slots properly so that they get locked ) so the screeching sound and windows rolling down problem is due to improper fitments.
The horn problem I never heard about on the forum, so cannot comment!
Old 3rd September 2010, 23:43   #6
Thanked: 86 Times
Hi Anil
Do post a link (or create a write up with pics here itself) to the detailed description n pics of the diagram for the screeching sound. Would love to get that sound out of my cabin once in for all. It's so irrritttaaatttiiiinnnggggg
I am facing another issue. At a certain RPM say arnd 1300, there is a kind of vibration from the left hand side in the cabin. Seems like it starts from the engine and travels all the way to the back. Any such issue being faced by any owner ? I own a diesel figo.
Diesel lover is offline   Reply With Quote
Old 3rd September 2010, 23:48   #7
anilisanil's Avatar
Thanked: 288 Times
Diesel lover, I am not sure if we can do that procedure at home but will try and post it here. And regarding the vibrations at low rpm may be due to wrong gear, if you are sure you are in the right gear then do take it to the service center.
The figo service manual has info on how to deal with vibrations if any!
Old 4th September 2010, 00:10   #8
Mpower's Avatar
Thanked: 1,682 Times
TSB is a circular sent to all dealers. & no they usually will not admit the fault to the customer. Only if its safety critical they will do a recall.
Originally Posted by Diesel lover View Post
Hpics of the diagram for the screeching sound. Would love to get that sound out of my cabin once in for all. It's so irrritttaaatttiiiinnnggggg .
take it to the dealer..should be covered under warranty
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
Screeching sound in Santro while turning Lalvaz Technical Stuff 8 26th June 2008 13:35
Screeching sound while steering Vinay DL Technical Stuff 4 28th November 2007 10:32
Indica Turbo --Screeching sound while starting?? werfish Technical Stuff 8 4th March 2007 14:18
screeching sound from the rear while going over bumps... amitverma Technical Stuff 16 30th August 2005 14:29
