Old 2nd September 2010, 19:33   #1
Thanked: 60 Times
Default Alto Trip Meter Resets to 0 on Turning Off Ignition
I have been using my Alto for over 3 years and have clocked about 30,000Kms to date.
Strangely, yesterday I replaced the audio system of my car, afterwhich the trip meter is automatically resetting to 0 each time the ignition is switched off.
I related this problem to the replacement of the audio system, however I can't seem to understand the relation between the electrical wiring of the audio system with that of the trip meter.
I've checked all of the fuses and also checked by removing all the electrical connections made to the new audio system, however the problem seems to persist.
The odometer seems to be working fine and so are the other electricals. Any help in this regard would be much apprecaited.
Yikes
yikes6633 is offline   Reply With Quote
Old 2nd September 2010, 20:01   #2
rjstyles69's Avatar
Thanked: 795 Times
yikes pretty strange it is, usually the culprit is a blown fuse. Since you confirmed having checked it all, look at the battery terminals and ensure they aren't corroded or loosely connected.
Old 2nd September 2010, 20:16   #3
bhp_maniac's Avatar
Thanked: 111 Times
Originally Posted by yikes6633 View Post
Yikes
Trip meters will reset only if the supply for memory from battery has gone. May be it can be attributed to the installation of the audio system. The installer may have unintentionally removed some of the connectors. Don't worry, must be a minor issue which can be fixed by the A.S.S.
bhp_maniac is offline   Reply With Quote
Old 3rd September 2010, 20:50   #4
Thanked: 60 Times
It's strange! I will take the car to the service station tomorrow and have them check it again.
Thanks for your suggestions
Old 6th September 2010, 12:52   #5
Thanked: 60 Times
Trip meter is working fine now. The contacts in the fuse box were disconnected from the wire behind it. The service mech soldered the same and it helped fix the issue.
DIY-Blue LED Parking Lamp & Speedo Meter+Wire Mesh Grille & Underbody Neons for Alto badboyscad DIY - Do it yourself 133 1st March 2015 00:50
i10 Trip display resets from Tripmeter to Odometer on restart jits_1998 Technical Stuff 19 6th September 2012 15:40
Baleno - Head light not turning off naveendhyani Technical Stuff 27 24th January 2012 22:16
car turning off while running harry2223 Technical Stuff 7 5th April 2008 22:46
engine hesitation when turning OFF 2fast4u Technical Stuff 13 14th September 2006 23:01
