Old 20th October 2015, 22:20   #31
pixantz's Avatar
Thanked: 733 Times
The hiccups you describe does not appear to be engine or misfire related. Suspect it to be related to an unbalanced pressure plate / uneven wearing of friction plate.
Get the clutch pressure plate and friction plate changed, and have the flywheel turned and balanced, or replaced.
Thanx ss-traveller. Actually I was thinking on the same thing a day ago as I got the exact same diagnosis from a mechanic guy when he listened to the symptoms. His take was that this can't be an electrical/ignition problem since the problem never occurs at standstill or startup. Never. No hiccup, no starting problem, no shivering, nothing. I'll look into it ASAP.
pixantz is online now   (1) Thanks Reply With Quote
Engine misfire in my Hyundai i20 CRDI: UPDATE: Issue resolved guyfrmblr Technical Stuff 24 8th November 2012 10:58
Opel Astra misfire/backfire Mpower Technical Stuff 12 6th October 2010 04:55
Getz: Low RPM misfire PraveenM Technical Stuff 12 14th September 2009 14:15
Deutz Engine Screensaver & Engine assembly/working animation mohit Shifting gears 19 14th July 2009 21:35
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
