Old 25th November 2005, 10:36   #1
ramkya1's Avatar
Thanked: 368 Times
Default Low Speed Ride Comfort
I often hear that the Fusion "crashes thro potholes and jarrs the passengers" its llow speed ride comfort is very bad. I haven't experienced any problems on low speeds, i have tested other sedans also.... I don't understand this concept:
1. If a car has bad low speed ride comfort how can it be better in high speeds?
2. Does having a fatter tyre (15,16 inchers) have a direct impac on this, can bigger tyres reduce ride comfort?
3. I know the suspension has a direct impact on the comfort, I would love to learn more details.
Thanks for the inputs.
----- Ramky.
ramkya1 is offline   Reply With Quote
Old 25th November 2005, 11:13   #2
Shan2nu's Avatar
Thanked: 89 Times
That's bcoz at low speeds there isn't enuf force hitting the suspension, for it to give in. But driving at a higher speed on the same piece of road, will force the suspension to give in a little more making the ride a lot more comfortable.
There are 2 ways to look at it.
1. If you compare a 205/60 R14 with a 205/55 R16, the one with the bigger wheels will hamper the ride quality bcoz the lower profile reduces the flexing characteristics of the sidewall.
2. Now, if you compare a 205/60 R14 with a 205/60 R16, the one with the bigger wheel size will infact improve your ride quality. Thats bcoz, even thought the wheel size has increased, the profile remains the same providing the same cushioning effect as a 205/60 R14.
And it doesn't end just yet. The 205/60 R16 has a much bigger rolling circumference which means that it'l ride over the potholes, rather than into them.
So you see, a bigger wheel isn't always bad. It's the profile and the rolling circumference that matters.
Shan2nu
Hi-speed and Low-speed jeeps? MalluDude 4x4 Technical 17 21st May 2012 14:17
Hatch Back Vs Sedan ( Ride, handling, comfort, Power, Space, etc) muni Technical Stuff 116 6th April 2012 20:19
What affects ride comfort? Samurai Technical Stuff 39 29th September 2010 18:15
Improve the Ride Comfort & Handling of Omni mithun Modifications & Accessories 14 17th October 2006 05:02
Performance and Ride comfort in one car? Samurai Sedans 84 12th April 2005 17:53
