Old 9th September 2010, 12:05   #16
anilisanil's Avatar
Thanked: 288 Times
Ford has replacement warranty for wiper blades for shuddering, just ask the service advisor if he could replace the wipers under warranty. The reason for shuddering/squeaking may be the accidental wiping in dry conditions!
I had similar problem in Figo and wiperblades were replaced under warranty!
anilisanil is offline   Reply With Quote
Old 9th September 2010, 12:19   #17
condor's Avatar
Thanked: 4,897 Times
Originally Posted by ghodlur View Post
.. 10 month old, stock wiper rubber on my Fiesta when purchased in Nov 2009.
Will be very good if you can get a warranty replacement. Else, dont sweat over it. Go for either Bosch or Syndicate. Remember - if you buy from the Ford A.S.S, they are likely to charge you for replacement also. (They do this for some simple replacements also). Check outside before you buy from the dealer.
Originally Posted by Speed Pujari View Post
Or, put some detergent in the wiper tank. Spray them while shuddering.
Again, not to scrimp on this. Better get a small bottle of windshield washer fluid. Available as small bottles in most accessories shops.
Old 9th September 2010, 12:29   #18
Thanked: 12 Times
The wipers must have caught cold !!!
Jokes apart, I think the blades need replacement. On casual inspection, they may seem to be fine, but actually the rubber may be worn off.BTW, how old are they?
auto-one is offline   Reply With Quote
Old 9th September 2010, 12:44   #19
sv1976's Avatar
My 12 month old Fiesta had a problem with wiper blades - though no shuddering, it was not wiping properly. And during my 3rd service two weeks back, the SA did point out this but didnt tell me it could be replaced under warranty. Are you sure that blades are covered under warranty or only the motor?
sv1976 is offline   Reply With Quote
Old 9th September 2010, 12:48   #20
ghodlur's Avatar
Thanked: 2,434 Times
Unhappy
Will talk to Ford and let you know once done. I hope they do it.
They are 10 months old.
Agreed, no point in hassling with Ford if they dont replace it under warranty. I guess Ford provides their brand of wiper blade rubbers if they are to replace it or I should buy form them and not the branded once like Bosch as you suggested.
BTW what would be the cost of the branded wiper rubbers. Should be well within 500/- right.
ghodlur is online now   Reply With Quote
Old 9th September 2010, 12:48   #21
anilisanil's Avatar
Thanked: 288 Times
Wiper blades warranty is for 6 months (somewhere I read 10 months too) or 10000 km whichever is earlier.
Yes I am sure about the warranty, I got the bill too where the wipers cost was given but I was not charged citing warranty. I will see if I can post the bill here!
For figo each one costed 194 (inclusive taxes) should be in that range for Fiesta too!
Old 9th September 2010, 12:58   #22
ghodlur's Avatar
Smile
@anilsanil,
Thanks for the information.
Will definitely visit Ford this weekend and get this thing sorted out.
Old 9th September 2010, 13:09   #23
vnabhi's Avatar
Thanked: 1,311 Times
As others said, it is definitely an issue with the blades---get 'em changed pronto. I agree it should have lasted longer. Mine lasted for 3 monsoons and I changed them only this year when I got that juddering sound.
Old 9th September 2010, 13:44   #24
condor's Avatar
Ford has this policy of not selling spares alone. Apparently every spare part used must go with a job card - and hence labor billing. This policy may be applicable to wiper blades also (though am not sure). Hence asked you to check prices outside & then compare with price at ford (incl installation).
Bosch / Syndicate are good enough. You can get them from outside & fix them yourself. I am using Bosch, and am fine with those. Bosch would cost you about 300 -330 for a pair.
Old 9th September 2010, 14:54   #25
Thanked: 44 Times
I have the same problem recently on my Baleno. I had just replaced the blades, which I do every two years, using Bosch blades, and I found one of them chattering across the glass, on the upward stroke.
Researched it on the net, and the culprit was pointed out to be either dirt on the blades (which mine did not have), oily film on the glass (which I had) and wiper arms to be adjusted so the blades rest perfectly horizontal on the glass (which was okay in my case).
I then remembered I had used Rain-X on the glass earlier. So I wiped it clean with lots of washing-up liquid, and wiped the blades as well. That did the trick, problem solved.
filcord is offline   Reply With Quote
Old 9th September 2010, 21:01   #26
vigsom's Avatar
Thanked: 604 Times
I have lately observing the wipers in my Ford Fiesta to shudder when they sweep across the front windscreem. There is also noise during the wiper movement which I supsect to be coming from the wiper motors. The shuddering happens to both the wiper blades and occurs when the wipers approaches the final edge of the sweep. What could be the reason for the same?
I have inspected the wiper blade rubber and found no cracks, chipping or any abuse. Similarly the wiper blade arm is freely operatable without any stickiness. This noise and the shuddering of the wiper is seen at all positions of wiper speeds - intermittent and variable speed positions.
Expert BHPians kindly advise.
MODS: If any existing thread available please merge.
this is just because the blades bottom get warped ; as a result on the upward/ return stroke, you feel the shudder and also see some irregular marks on the windscreen.
Yes,the best solution obviously is a replacement.
A "gol maal" solution,though, is to bend the wiper arms slightly,which is just not advisable
Old 9th September 2010, 21:09   #27
anachronix's Avatar
Thanked: 1,294 Times
Off-topic:
I have bought spare parts (including an alternator) off the shelf for my Ikon and recently bought a 1-Din trim kit for my Fiesta from Ford dealer.
anachronix is online now   Reply With Quote
Old 10th September 2010, 18:09   #28
Thanked: 44 Times
Incidentally so does Maruti. I needed to replace my air-filter recently, and the local Sai Service told me they must make a job-card, even though I am perfectly able to remove the old filter and replace it. It sounds like a restrictive trade practice to me.
Old 10th September 2010, 18:37   #29
condor's Avatar
Maruti spares are available across the counter from Maruti's spares dealers. Not so with Ford.
@Filcord, what you have experienced would be the case with that particular Maruti A.S.S only
Old 11th September 2010, 22:38   #30
Thanked: 44 Times
I don't know. Perhaps MASS and Maruti dealers will not sell spares over the counter any more, because I have had this experience with both Sai and Chowgules, the only Maruti dealers in Goa. Is there any other sales outlet besides dealerships?
Shuddering/Vibrations while braking! Need help! asethi Technical Stuff 76 17th February 2013 18:16
Mahindra MM550's rear starts shuddering at 60+ kph lugnut 4x4 Technical 8 16th March 2012 13:00
Shuddering on Civic surfatwork Technical Stuff 18 9th February 2009 22:56
