Old 12th September 2010, 10:17   #1
Motoringlover's Avatar
Thanked: 179 Times
Default Need Advice - Replacement for E220 W124 Headlight
Hi Team,
I am starting a new thread, as i was not able to find something similar to my requirement.
Need help, I am currently looking for support on getting better headlamps for a 1996 W124 (E220), the lights are fine, but just need a better lighting in the car, the goal is to improve the night time driving visibility.
Mods : Sorry if this is posted in the wrong segment,
Please advise.
Motoringlover
Motoringlover is offline   Reply With Quote
Old 15th September 2010, 00:21   #2
Thanked: 660 Times
Provided your glass and reflector are in tip-top shape, change to a higher wattage bulb.
I don't think HID is effective in Non-Clear glass lamp. Say what gurus?
Old 15th September 2010, 22:18   #3
Thanked: 103,475 Times
+1 to Sir Alec. If you're running the reflectors & headlamp glass that came with the car, it's way too old. Replace & while at it, get yourself better bulbs.
Old 15th September 2010, 22:31   #4
nitrous's Avatar
Thanked: 285 Times
Replace with OE headlight assemblies. Not Chinese replicas.
Old 15th September 2010, 22:52   #5
Thanked: 139 Times
There seems to be no easy solution here. i have been trying to get steiger to upgrade my lights last two years since i started my weekly trip to pune. my returns have been invariably at night and at 130 to 140kmph, the w124 is way ahead of its lights (or beam, if you get what i am saying)
Steiger says its not easy to do. There are some electrical limitations prior to the reflector and light. getting new units might help a bit
What we have finally decided to do is get PIAA pencil beams and fit them extra. got the idea while looking for fogs for the Jeep. They should cost you 180usd on ebay plus shipping and customs. Will be still cheaper than getting OE replacement lights
53BHP is offline   Reply With Quote
Old 15th September 2010, 23:49   #6
msaudf's Avatar
Thanked: 152 Times
have you tried to clean the existing headlamps? they should be glass so brightening the glass and the metal reflector is a doable DIY. or if you feel like you want a trained person to do the disassembling and assembling its not a bad idea.
i faced a similar problem in my 124 and my problem was solved by cleaning the unit and upgrading the bulbs and adding an extra relay.
msaudf is offline   Reply With Quote
Old 17th September 2010, 13:20   #7
Thanked: 179 Times
Default Update
@ Nitrous We were thinking OE, but my fil feels he has always felt the need for better lighting in the car, it could very well be his age factor now.
Old 17th September 2010, 13:28   #8
Thanked: 179 Times
Default update 2
@53 bhp - thanks for the advice.
@msauf - Already tried, i guess its eithers the replacement (standard) or upgrade if possible .
Old 17th September 2010, 15:13   #9
Thanked: 179 Times
Thanks siralec, any advice on the brand recommended ?
Old 17th September 2010, 20:11   #10
msaudf's Avatar
Thanked: 152 Times
these would look cool.
Old 21st August 2012, 11:36   #11
Thanked: 154 Times
Default Re: Need Advice - Replacement for E220 W124 Headlight
Dear 53BHP,
Can you share a picture of the same. How effective have these been?
Can you let me know a reliable place to get this done.
TIA
vikramvicky1984 is offline   Reply With Quote
Old 18th October 2012, 18:57   #12
Thanked: 139 Times
VikramVicky,
I have not yet installed these. Just involved in too many projects at the moment.
Here is the Piaa link though:
http://www.piaalights.com/details.ph...XTREME%20WHITE
Its around 150 to 200 dollars overseas
Go for the driving lights with the narrow beams
Best
R
53BHP is offline   (1) Thanks Reply With Quote
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
Buying Advice regarding 1996 W124 E220 Petrol aquavelva Luxury, Imports & Niche 17 26th August 2013 18:18
Mercedes E220 (W124 series) setup Raja In-Car Entertainment 38 21st June 2013 09:47
My "new" Mercedes E220 (w124 series) Raja Test-Drives & Initial Ownership Reports 44 19th February 2010 10:54
