Old 16th September 2010, 20:18   #16
yzfrj's Avatar
Thanked: 118 Times
Originally Posted by humyum View Post
I wasn't charged a penny , mine is a 2008 December model.
Does this apply to the Dezire-D as well ?
Can you please post a pic of the "new" booster.
Will M.A.S.S guys play dumb ?
(Whaat saar we no know saaar, swift brakes are like this one-ly)
Need to inform my dad he has a Swift -D July 2008
and Bro to he has a Dezire-D Dec 2009
EDIT :
Originally Posted by mtnrajdeep View Post
I read this circular at Pratham Motors. I mentioned that it was only for the non-ABS models. I will check again this saturday and post on the forum. There was another circular about a modified mount for reducing clutch pedal vibrations as well. I dont remember the details clearly but will check once more.
Can you please post a copy if you have one.
yzfrj is offline   Reply With Quote
Old 16th September 2010, 20:43   #17
buntydey's Avatar
Can someone enquire the cost of the brake booster when you guys go to MASS for the change. I have a Swift Petrol Vxi, and I always had this feeling that the brake is not adequate. Might go for the upgrade at own cost.
buntydey is offline   Reply With Quote
Old 16th September 2010, 21:32   #18
sachinj12's Avatar
Thanked: 161 Times
Since when was the new booster factory fitted? My Dzire is Jan 2010 manufactured, can anyone tell me whether I am running new or old? I didn't find any significant difference, but yes 3 digits is bit scary.
sachinj12 is online now   Reply With Quote
Old 17th September 2010, 08:54   #19
goandude's Avatar
Thanked: 437 Times
great news for swift/dzire owners. Will remove one significant weakness in the car.
goandude is offline   Reply With Quote
Old 17th September 2010, 10:18   #20
Ajaybiz's Avatar
Thanked: 140 Times
Mine is Nov 2007 non abs model and last month came after servicing where i mentioned weak breaks but theres no changes at all they just replaced some small part in both front break calipers thats it, breaks are still weak as it was, whats the procedure to get it done i dont mind paying as well if its really going to work like petrol cars.
Will check once again in pratham motors as they are quite close to my flat at ORR.
Ajaybiz is offline   Reply With Quote
Old 17th September 2010, 11:36   #21
humyum's Avatar
Thanked: 2,188 Times
Costs around 3200 bucks, not expensive. With Labour I guess it should reach the 5 thousand mark as u ll need new brake oil too. But its totally worth it.
EDIT :
Yep for Dzire D as well.
The circular came in 4th or 5th month, so now sure if yours has the new brake booster or not. I guess a MASS could check it out with the model number ?
Just ask them to change the brake booster to a new model ones , which has a bigger diaphram ( not sure how to spell this ). This should do the trick.
Old 17th September 2010, 12:08   #22
im_srini's Avatar
Thanked: 368 Times
Infractions: 0/1 (5)
Question
Costs around 3200 bucks, not expensive. With Labour I guess it should reach the 5 thousand mark as u ll need new brake oil too. Just ask them to change the brake booster to a new model ones , which has a bigger diaphram ( not sure how to spell this ).
Hi HumYum, is the master cylinder being changed along with the booster ?
I'm just wondering if the booster is from the SX4...
im_srini is offline   Reply With Quote
Old 17th September 2010, 13:27   #23
sonirohit's Avatar
Thanked: 9 Times
I called up regional maruti HQ after getting to know about this change.
Talked to their service head - he denied receiving any such circular or intimation from MUL about replacing the boosters for swift D.
Let me raise a fomal complaint about the brakes being weak with the regional office of Maruti - let's see if something good turns out from it.
sonirohit is offline   Reply With Quote
Old 17th September 2010, 13:36   #24
KA18's Avatar
Thanked: 16 Times
Two of my friend's sold their Swifts due to the narrow escapes they had because of the weak brakes at high speed.
Guess they were a little hasty, this should be good news for existing owners.
It is spelt 'Diaphragm' and pronounced 'Dia-phram'.
KA18 is offline   Reply With Quote
Old 17th September 2010, 14:08   #25
Ajaybiz's Avatar
Thanked: 140 Times
Humyum in your previous post you said that they didnt charged you anything and just now you said the quote will be around 5K, kindly clear the picture.
Old 17th September 2010, 14:36   #26
humyum's Avatar
buntydev said he ll upgrade the booster at his own cost, so I told him that if he upgrades it at his own cost, it should cost around 5 thousand rupees at max.
I got mine done for free only
Old 17th September 2010, 15:22   #27
mtnrajdeep's Avatar
Thanked: 88 Times
The circular I saw did not mention anything about replacing the boosters. It just mentioned that there has been a design change for the non-ABS models. It was more like information to the people working in the workshop.
mtnrajdeep is offline   Reply With Quote
Old 17th September 2010, 15:43   #28
Thanked: 51 Times
What about Ritz diesel? Does the circular talk about this car also? My Ritz vdi is Dec 2009 model.
gaddiwale is offline   Reply With Quote
Old 17th September 2010, 16:17   #29
mtnrajdeep's Avatar
Thanked: 88 Times
It was for both Swift and Ritz diesel non-ABS models.
Old 17th September 2010, 16:33   #30
f1fan's Avatar
Thanked: 41 Times
Originally Posted by ab.kolan View Post
I called Bimal they told rs. 9000/- for upgrade the new break the boosters Swift Dizre D. If I go I will be the first one in the Bimal this upgrade.
How old is ur vehicle? Did Bimal talk about replacing the same free under warranty?
f1fan is offline   Reply With Quote
My BRUTE-FORT: Toyota Fortuner 4x4 M/T [Upgraded Brake Booster & A/T Tyres] EDIT: Now sold! karan561 Long-Term Ownership Reviews 232 14th December 2017 23:20
Booster Brake Adjustment - Is it possible? mail4ajo Technical Stuff 31 30th September 2015 21:31
Brake Booster Failure on a New Ford Fiesta 1.6S. Need help/info! capt_rocker Technical Stuff 37 1st November 2011 17:39
Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc Trust_In_Thrust Modifications & Accessories 26 6th June 2010 12:42
Brake booster Assembly of the Indigo joecherian Technical Stuff 22 9th June 2009 14:27
