Old 23rd September 2010, 13:13   #16
Thanked: 1,172 Times
So, you would be banging your head with the dealer and Ford every 10,000KM?
I am sure you will wear out faster than them.
My Tucson clutch has a short life and Hyundai say that's because it's full time 4WD. I told them that I can not live with such frequent clutch overhauls irrespctive of the reason - it's inconvinient as well as expensive and they should supply either upgraded clutch disks or subsidize the price. There are other Tucson owners who are also following up.
The manufacturers should understand that buying an SUV is one thing while maintaining it is another. It's sad that these famous vehicles actually have such issues that manufacturers are aware of and doing nothing about.
Sometimes I wonder, do they really test the cars for say 50,000KM before launching?
They should.
anandpadhye is offline   Reply With Quote
Old 23rd September 2010, 13:39   #17
siddheshb's Avatar
Thanked: 251 Times
Anand, I hope this is a one-off experience for me with my disks - but one thing is sure, the moment I hear a screech I am rushing to the dealer for pads
And regarding the clamping feeling in the brakes at the start of the day, yes, I get that too on my Fiestas and I was told it is because the pads "stick" to the discs because of the water blah blah, and it's nothing to worry about.
What worried me a lot though, is that a few days back, my left rear tire simply got stuck and refused to rotate, even when the other 3 were moving - and Ford emergency service told me the hand brake cable had got stuck... anyone had similar issues before?
siddheshb is offline   Reply With Quote
Old 23rd September 2010, 15:34   #18
vnabhi's Avatar
Thanked: 1,317 Times
Originally Posted by suman View Post
Don't worry till such time that you start feeling a shudder in the steering wheel when you brake at medium to high speeds. That indicates a problem with the Discs.
And, contrary to Siddhesh's pleasant experiences, Fiestas do exhibit disc issues - as mentioned below, I've had problems & so has Unni (to name a couple off hand).
Thanks. I'll keep a hawk's eye on the brakes from now on till the warranty expires.
Old 26th September 2010, 11:05   #19
MileCruncher's Avatar
Thanked: 357 Times
Venu saab, since yours is a low mileage vehicle, I suggest you get the check done nonetheless. All you require is to take off the wheels and do a visual inspection for the waviness on the disc.
MileCruncher is offline   Reply With Quote
Brake Discs for SwiftD?! asethi Modifications & Accessories 9 13th April 2012 23:54
Swift - Wheel Discs and Brake Pad problems ravi23 Technical Stuff 25 18th August 2010 15:07
Are Cross Drilled / Slotted Brake Discs Available For A Esteem ?? Tool Modifications & Accessories 2 27th December 2006 02:38
